Power steering pulley?
  • 1 Post By soyomb
Old 17 Jan 2013, 09:31 pm
Lightbulb Power steering pulley?
Hello everyone. I posted awhile back about noise from under hood, thinking I was a/c comp. New issue came to light; noise (high whine), just went away. Along with power steering. Found belt laying inside front fender. So, the p/s pump pulley has a piece broken off. Is there a tensioner or idler pulley between p/s pump & a/c comp? Could/would that have been noise, or the pump? Thanks for reading this long story, & thx for any input u may have.
Luckymagruder
'01 Silver Limited Edition
No Mods,Yet!
Flip-Out DVD, 12"Kenwood Sub,800w Kenwood Amp
Old 17 Jan 2013, 09:40 pm
Default Re: Power steering pulley?
Yes, in the picture below, the small wheel is the tensioner for the serpentine belt.
Old 17 Jan 2013, 10:13 pm
The wine was most likely the belt spinning on a pully that was not turning, or rubbing against the side of the tensioner. Autozone has them for like $35.
Have to rip the entire splash guard out of the wheel well to get to it, but once you've done that its pretty simple :-)
*trick to getting the splash guard out easy, remove the pencil strut ;-)*
Old 18 Jan 2013, 07:33 am
Ok. Must vary model to model or yr to yr. The belt I found was def not serpentine. Was told it runs off crankshaft & powers ac & ps. ???
No Mods,Yet!
Old 18 Jan 2013, 11:57 am
that's what the serpentine belt does. turns the ps and ac pulleys. that's all it does. if you're thinking it's all one belt according to crewzin's illustration, it's not. the belt on the left is seperate and is for the alternator.
Busted_PT likes this.
2016 Kia Soul Plus Black
Old 18 Jan 2013, 07:33 pm
Ok. That cleared it up. I did indeed think it was all 1 belt. So, I shall try my luck w/ replacing tensioner 1st. Seems that's where most people talk of noises & failure. Before belt flung, even with the noise - power steering still worked great. I appreciate everyones help and input. Hopefully I don't get called in to work, & I can have update on repair Sunday!
No Mods,Yet!
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Power steering tensioner pulley DODGETHIS Tech & Performance Forum 2 09 Apr 2012 03:22 pm
Bad:A/C & Power Steering Pulley Bluecruiser Tech & Performance Forum 0 11 May 2010 02:30 pm
Power steeing pump pulley csd Tech & Performance Forum 0 19 Jan 2010 12:30 pm
Power steering pump pulley ? JGN General PT Cruiser Discussions 10 22 Aug 2004 07:49 pm
