rough starting
Old 19 Jan 2013, 05:49 am
Location: Warmsley Manor, Tunbridge Wells Kent England UK
Default rough starting
Hi when i start my 2000 pt cruiser first time in the morning it starts very rough for a moment or to then picks up and a cloud of blue smoke comes from the exhaust.. after that its ok all day any suggestions???
Old 19 Jan 2013, 08:47 am
Default Re: rough starting
Blue smoke is oil burning. From the small amount of car information you gave. Sounds like valve seals. Not a common thing here in the states.
Old 19 Jan 2013, 10:49 am
Another possibility is the spark plug seals in the valve cover. Pull your plugs (and change them and the wires) and see if they have oil on them.
Old 19 Jan 2013, 06:32 pm
I will check the plugs and change the leads as they seem to be a problem with the 2.0l auto cruiser, but if its the stem seals why does it start and run without this problem when hot? as i would have thought it would be worse when the oil is hot and less thick. thank for the advise anyways .
Rough Starting hansjolo General PT Cruiser Discussions 0 27 Nov 2011 07:21 pm
Looking for starting help bluesanity General PT Cruiser Discussions 3 20 Mar 2010 12:16 pm
'03 Not starting GunnerIke Tech & Performance Forum 6 29 Oct 2009 09:55 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Rough idle, hesitation when starting off CREWZIN Tech & Performance Forum 4 30 Mar 2004 12:10 pm
