2.0 vs 2.4 PCM computer??
Like Tree4Likes
Old 19 Jan 2013, 08:13 am
Default 2.0 vs 2.4 PCM computer??
Hi there,
I ordered an OEM PCM and had it flashed with the new updates, VIN, and mileage. The reason was for the P0601 code on my 00 PT 2.0 auto. The PCM arrived but the paper stated 2.4. After I plug in, the new ECM immediately displayed the P1495 code. The P0601 is gone with the new ECM, but now I have the P1495 code and would not start.
I re-installed my old ECM and no longer get the P1495 code, but the P0601 code is there.
I was checking to see if any of you have ran into this with an ECM/PCM replacement. Do you think that the new ECM was sent defective or 2.4 is a problem...?
P.s My Pt was manufactory USA and I am having this car in Hong Kong. There is only 8 in Hong Kong so I could not get much help here.
I order the PCM from USA and it seem I have to send back to them for resend. I hope they will take the shipping cost as it cost around $100 in one way.
Thanks and your suggestion is highly appreciate!
Old 19 Jan 2013, 08:23 am
Default Re: 2.0 vs 2.4 PCM computer??
To my knowledge all PTs were manufactured in Mexico. The 2.0 was only used in export models. Doubt that the two would use the same computer.
Old 19 Jan 2013, 09:23 am
There was also a manufacturing plant in Graz, Austria for some of the European models of the PT Cruiser.
http://en.wikipedia.org/wiki/Chrysler_PT_Cruiser
Manufacturer DaimlerChrysler (2001–2007)
Chrysler LLC (2007–2009)
Chrysler Group LLC (2010)
Production 2000–2010
Assembly Toluca, Mexico
Graz, Austria (EUROSTAR)
Class Compact
Body style 5-door hatchback
2-door convertible
Layout FF layout
Platform Chrysler PT platform
Engine 1.6 L EJD I4
2.0 L ECC I4
2.4 L EDZ I4
2.4 L EDT/EDV Turbocharged I4
2.2 L EDJ Diesel I4
Transmission 5-speed Getrag manual
4-speed 41TE automatic
Wheelbase 103 in (2,616 mm)
Length 2001–2005: 168.8 in (4,288 mm)
2006–2010: 168.9 in (4,290 mm)
Width 67.1 in (1,704 mm)
Height 63 in (1,600 mm)
Convertible: 60.6 in (1,539 mm)
Curb weight 3,123 lb (1,417 kg)
Related Dodge SRT4
Designer(s) Bryan Nesbitt
Old 19 Jan 2013, 09:55 am
Thanks guys
However, my most concern is the computer which the OEM company company sent me a 2.4 but my is 2.0.
Hope anyone who could share me your comment and experience? I can not get any help here in Hong Kong but it is really cool to drive PT here.
Old 19 Jan 2013, 05:19 pm
UptownSport's Avatar
Swap the two outer wires on coil connector or swap spark plug wire #1 with # 2, and #3 with #4
Old 19 Jan 2013, 09:43 pm
swap two outer wires on coil connector seems easier than swap the spark plug wire, is it? Can you pls share me more detail where is coil connector and what color of the wires which need to be swap.
BTW, pls can you share me more about why we need to swap the wires?
Many Thanks:-)
Old 19 Jan 2013, 10:07 pm
if swaping spark plug wire #1 with # 2, and #3 with #4 is easier pls kindly share.
Pls also explain why we do this? Many Thanks
Old 19 Jan 2013, 10:34 pm
It is my email address Johnnytcng@yahoo.com.hk and I would appreciate if you could send me pictures to shows how to do and the location. Many Thanks
Old 21 Jan 2013, 12:41 am
Why:
Pretty EZ to swap plug wires.
Old 21 Jan 2013, 09:51 pm
Why:
if i swap the plug wire #1 with # 2, and #3 with #4, will this do any bad for the engine? is 2.4 vs. 2.0 the only different is the plug wires location? Many thanks
DO I NEED A NEW COMPUTER? pLEASE HELP ChickenMan Tech & Performance Forum 10 03 Jul 2012 11:23 pm
computer chip or after market computer?? mdskinner731 Tech & Performance Forum 3 08 Nov 2011 02:08 pm
MPG computer on PT vtmdsm27 General Turbo Discussions 4 20 Oct 2008 10:28 am
