Speedometer needle bounces on cold start up
Old 19 Jan 2013, 11:21 am
Default Speedometer needle bounces on cold start up
2002 PT Cruiser Limited, auto with high mileage. For a long time my wife's Cruiser has had this problem. When you first start the engine, the speedometer needle bounces and it adds miles onto the trip meter. All of this without ever putting the car in gear. The engine will also rev up and down on its own and when the engine revs up, the speedo pegs the max even without the car being put into gear.
It only does this for the first few seconds after start up. Once you put it in gear, the problem seems to disapear.
No engine code either
Any thoughts
Old 19 Jan 2013, 11:29 am
Default Re: Speedometer needle bounces on cold start up
Check the battery and the whole charging system plus look at all your wires and cables to make sure there's no corrosion on the cable ends. A weak battery plays havoc on the electrics.
Old 19 Jan 2013, 12:22 pm
Thanks for the response.
It has a new battery (3 months old) and this battery change had no effect on the start up issue. I will double check the wiring and make sure the ground wires are good. I will give you an update if this helps or not.
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
Cold Start ahaddad Tech & Performance Forum 6 29 May 2012 10:02 pm
Cold Start Roughness??? ptguy69 Tech & Performance Forum 3 11 Jun 2010 01:19 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Replaced battery - Speedometer needle is off the peg rexdogga3 General Turbo Discussions 3 07 Oct 2008 07:01 pm
