PT Cruiser won't crank / start
Like Tree8Likes
Old 19 Jan 2013, 07:48 pm
Default PT Cruiser won't crank / start
My girlfriend has a 2005 PT Cruiser convertible, will not crank... no apparent previous symptoms
I've checked all fuses, swapped out start relay.
I jumped posts 30 and 87, and the starter cranks reliably, so I know both the battery and starter solenoid are good. Post 85 has very low impedence (.145 ohms) but is not ground.
Posts 85 and 86 fluctuate very slightly (not measurable) but stay at 0 voltage when I turn to start. I understand they are supposed to get 12v from starter switch. Though I don't regularly drive this car, it seems that the starter switch does not have a positive spring return from the start position; I suspect this might be a physical problem
I also understand there is an actuator pin that can go bad behind ignition lock. 1) Is there a way to further test the ignition switch before I take it apart and 2) Is there something else for me to test / troubleshoot?
There is no check engine light, car will not start in neutral, door lock remote works, and moving the steering column does nothing (tips from other posts
Old 19 Jan 2013, 08:52 pm
Default Re: PT Cruiser won't crank / start
Someone just had a similar deal. Turned out to be the ground behind the airbox.
Old 19 Jan 2013, 09:14 pm
Thx. It's dark now (and still raining). I'll check in morning. Am I looking for a groundstrap or cable to the firewall? Can you be a little more specific as t owhat I'm looking for?
Old 19 Jan 2013, 09:35 pm
The ground cable runs to the driver side inner finder hidden by the air cleaner box. Any connection or junction is a possible dirty connection.
Old 19 Jan 2013, 09:54 pm
Thanks. Actually, I think I saw that; a acble clamped w/ 2 10mm bolts. I checked f/ tightness, but did not take off to clean. Will go thru all tomorrow.
I also read that pcm could be bad.. not sending neutral to relay to engage starter. Don't know how to check that, other than replace pcm...Really don't want to go there
Old 19 Jan 2013, 10:57 pm
I would go through every cable connection from battery to starter before I would spend any money. Do the cheap stuff first.
Old 26 Apr 2013, 06:04 pm
Im having a similar problem.
What was the resolution here?
Old 26 Apr 2013, 06:27 pm
We would need much more information on your exact symptoms, model, year, turbo/non turbo, any engine codes etc before knowing what to tell you lol
Old 18 Dec 2013, 06:17 pm
My PT stopped on me three times today. Each time I was driving, foot on gas pedal and I felt the pedal lose pressure as the car came to a stop. The car still had battery power but would not crank. After a few minutes it started up and I drove it. The third time it stopped on me (about 30 minutes later) it wouldn't start. Still won't crank up. There is battery power, the starter isnt broken (my husband tested it). We don't know whats wrong. 2004 Pt Cruiser GT
Old 18 Dec 2013, 08:22 pm
randyincctx's Avatar
Lightbulb Re: PT Cruiser won't crank / start
If you any where near (or past) 100,000 miles,it could be the timing belt......Easy way to check,is to have your husband remove the camshaft position sensor,and while he's looking inside the opening,you try to crank the car....If it doesn't turn,it's the timing belt.
Aka:~KILLER~
2004 Will not crank or start gatorglenn Tech & Performance Forum 10 05 Oct 2012 07:40 pm
02 Cruiser, won't crank ohwell Tech & Performance Forum 5 27 Jun 2012 09:14 pm
03 crank no start. spike General PT Cruiser Discussions 3 19 Jan 2012 08:44 am
01 stalled, no crank, no start - thoughts? darwal61 Tech & Performance Forum 7 06 Jan 2012 06:14 pm
02 pt cruiser won't crank over. vanhalen7174 Tech & Performance Forum 2 04 Apr 2010 12:06 pm
