03 pt cruiser turbo plug gap
Old 21 Jan 2013, 12:43 pm
Default 03 pt cruiser turbo plug gap
Hi, I got autolight xp iridium and crane wires for my 03 pt cruiser turbo autostick. The only thing not stock is the exhaust is free flowing. the car has 96,000 miles and has a stumble at red lights and seems to be eating alot of gas. It has the stock wires so im guessing it has stock plugs in it. When im stopped at a red light the oil light flickers. Im sure its because of the idle because when I put it in neutral it goes off.
I called the dealership and they said I need to gap the plugs to .050 on the 03 pt cruiser turbo. I thought .050 was for non turbo.
What would you gap the plugs?
I havent changed the plugs im waiting on you guys to reply.
Old 21 Jan 2013, 01:34 pm
Default Re: 03 pt cruiser turbo plug gap
don't know but change the wires to anything but oem. that's probably where the problem is.
2016 Kia Soul Plus Black
Old 21 Jan 2013, 04:03 pm
I believe it's a 40 at the moment. Haven't run into any issues with the OEM wires. So they should get replaced also. Bet you were all over that already.
Old 21 Jan 2013, 05:01 pm
Yeah I got crane wires, ive read a lot about the plug wires on these cars. I found couple of post on here where people gap to .035 does that should good or are those for modified cars?
Old 21 Jan 2013, 06:17 pm
I split the difference and went to 0.038.
There was a tech service bulletin that reduced the stock 0.050 gap to 0.040.
The gap will widen with time.
I checked my plugs before I put them in - wide variation.
I used a small block of wood to gap - Drop the plug on the wood to close gap, hook electrode on edge and tug to widen.
Be careful with that center electrode.
Old 21 Jan 2013, 06:35 pm
Thanks im going to go with .038 I thought i was going to get my wires in the mail today but it didn't run.
Old 21 Jan 2013, 07:00 pm
No mail delivery today...
Old 21 Jan 2013, 07:53 pm
needmoretoys's Avatar
I have mine at 35 with no issues
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 22 Jan 2013, 06:06 pm
I got the plugs and wires changed out today. Current the gap is set at .048 has a dead spot if you stomp it from idle in neutral for a split sec.
The plugs I pulled out where ngk platinum gap at .035 So I tryed it there at first, It had a pinging sound coming from the engine. the dead spot was bad if I just floored the throttle from idle. I pulled them out and set the gap to 40 which was ok. still had the dead spot but no more pinging sound coming from the motor. now its at .048 still with a dead spot is that normal on a turbo engine? what do you recommend i should do now?
Old 23 Jan 2013, 12:21 pm
2step's Avatar
"Pinging" and a spark miss are two different animals. Pinging has a lot to do with the quality of the fuel and the heat range of the plug but not the gap. The reason some of us close down the plug gap less than the factory recommendation is because some of us mess around and raise the boost higher than factory. Higher boost (compression) is more resistant to spark jumping the gap so depending on your particular driving style and boost, a smaller gap may be better. There is no one-size-fits-all. There is a benefit to a bigger gap so long as it's not so big that it causes a miss. I was running a big turbo with 23/24 psi boost so, yea, a gap around .038 made sense for me.
Best NGK Copper Plug 2003 GT Turbo Soulman Stage Turbo Kits 5 10 Mar 2012 01:57 pm
how much will spark plug tune up run on GT Turbo BrianW General Turbo Discussions 2 06 Jul 2010 10:53 am
Part# for MSD Plug wires for 2006 GT 2.4L Turbo... PA_NC_Cruiser Tech & Performance Forum 1 05 Apr 2010 10:53 pm
2006 non turbo spark plug change samson77 Tech & Performance Forum 9 06 Feb 2007 12:36 am
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
