oil light
Old 22 Jan 2013, 07:57 pm
needmoretoys's Avatar
Default oil light
I know that the oil light is an issue on our cars. Does it make any sence that the oil light would come on more when it is cold out, after driving it for at least 1/2 hour? I will check the oil again tomorrow morning when I get out of work but something doesn't seem right. It was 20 degrees out and I am using synthetic oil. The light was only coming on after I'd get on the car a bit. I will be changing the oil pressure switch but when it gets warmer.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 23 Jan 2013, 09:44 am
cruserdad1976's Avatar
Default Re: oil light
its not really the light its the oil sending unit that actually turns on the light its bad just change it out and you should be good to go its a cheap kinda sorta easy DIY
Old 24 Jan 2013, 01:02 am
Yeah thats what I thought. I checked the oil and it was fine.
Lenny
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
