Possible engine build on the horizon
Old 23 Jan 2013, 09:33 pm
cruisin03pt's Avatar
Default Possible engine build on the horizon
Hey guys, its been a while. Ive been seriously thinkin bout building up the engine in the pt. hopin to get over 200whp out of it if i can.
Cams: either crane 22's or crower stage 2's
Crower valve springs
Oversized valves- not so sure on this one just yet
P&P dohc intake manifold
Atx 60mm throttle body
24lb injectors with a 58psi regulator
Walbro 255 fuel pump
Megasquirt pcm
Aftetmarket header
2 1/2" free flow exhaust
Super 44 series muffler
Underdrive crank pully
AEM adjustable cam gears
Decking the head (0.020-0.045)
Possible high comp pistons
Any thoughts?
Old 24 Jan 2013, 03:47 am
UptownSport's Avatar
Default Re: Possible engine build on the horizon
Not sure about valves, either- Surprisingly one thing that wasn't discussed on Neon forum. It's clear you don't need them, tho!
I'd suggest a stock head, milled as you please. I assume you can remove Headgasket Shim in the new 2.4, make a post asking for old ones so you can do an autopsy to find out!
Do this after you decide on pistons, I'd like to see flattops but it'd end up in the high to very high category: E85 only
I'd use stock injectors and regulator with MS- unless you E85 in your area:
Alternative Fuels Data Center: Ethanol Fueling Station Locations
You won't need a different fuel pump in any case! Stock is more than enough for NA.
You need to get someone to bend a Long Tube Header for the PT body-
My suggestion, though, is to do all the 'bolt on's first, and see where you're at.
Old 24 Jan 2013, 02:42 pm
Thats what i was thinkin. Better to start off cheap and then work my way up. Now as far as a throttle body, whats tue biggest i can go without being too big? And im having a hard time finding megasquirt pcm for an n/a car. Any suggestions?
Old 25 Jan 2013, 02:21 am
I'm not sure you can go too big, BUT you'll have problems unless you make the throttle bellcrank progressive-
IOW, just touching throttle will allow LOTS more flow than on a tiny TB the same angle.
One Neon guy put an 80mm on his 2.0!!!
All MS do the same thing whether Turbo or NA- Boards are exactly same except V3.57 mass production and the old V2.2 (not sure there's code for NGC)
A V3 MSI will work fine- You'll need Neon/420A code for 2.0/2.4 '02 and older, or NGC code for '03 & Up
Here's a how-to build index- $200 for the kit
Minnesota's Community of Neons! • View topic - MS Build Index
For MSII the processor is what's different, and one jumper
MSIII, same except you need a taller case.
Old 25 Jan 2013, 09:36 am
Cams: either crane 22's or crower stage 2'si
Megasquirt pcm
Aftetmarket header
Any thoughts?
I would do a chases dyno to see exactly were your at. The throttle body size not that big of deal. The intake is like a restrictor in NASCAR. If you don't get more flow there the TB won't help much.
Old 25 Jan 2013, 11:23 am
where did you hear that from........
Old 25 Jan 2013, 11:28 am
I think I heard it off the forum some were?
Old 27 Jan 2013, 08:07 am
Having no luck finding another intake manifold. Got any ideas?
Old 27 Jan 2013, 02:25 pm
You mean a 2.0 DOHC manifold?
Old 31 Jan 2013, 05:50 pm
Will it help?
PT in a Box the Model Build NitroPT Members PT Project 16 09 Dec 2012 12:57 am
The new build cruisin03pt Sound and Security Forum 0 08 Sep 2011 11:26 pm
carbon build up under engine cover 2.2 diesal scamp33 Tech & Performance Forum 7 18 Jan 2011 12:22 pm
Build it or buy it dcartwright PT Cruiser Convertible Forum 2 08 Sep 2009 05:39 am
Build-Your-Own MBC Jason_L Turbo Performance 0 27 Jan 2004 03:39 am
