2004 Model ignition switch feed
  • 1 Post By lostinoregon
Old 25 Jan 2013, 12:24 pm
Default 2004 Model ignition switch feed
Hi,
Does anyone know if the ignition switch feed coming from Fuse 1 in the PDC only goes straight to the ignition switch or does it also go and feed something else before it gets there too?
I have a diagram from a 2002 model which shows it only going to the ignition switch but could be different on the 04.
Thanks,
Nick
Old 25 Jan 2013, 02:04 pm
Default Re: 2004 Model ignition switch feed
I have a '03 book and it shows Fuse 1 {30a}, go's from PDC to S123 1n PDC. Fuse 3 {40a } go's from PDC to Ignition Switch with a splice going to Fuse Block. I hope this helps.
Ken
Old 25 Jan 2013, 02:40 pm
sanatanadharma's Avatar
It's not a diesel, correct? The diesel has a 150 amp mega fuse between the battery and the PDC.
My 2004 shop manual confirms what lostinoregon says, save the C105 connector prior to the ignition switch C1.
The inner PDC splice (S123) feeds the starter motor relay in the PDC.
On an Auto-stick, a splice at ignition switch C1 feeds ignition switch C2 through the fuse box, fuse #16 (10 amp).
PDC fuses #3 & 20 also feed the ignition switch.
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 25 Jan 2013, 06:11 pm
Thank you lostinoregon and sanatanadharma!
Yes it is a Diesel.
Basically, I have the ignition feed to Pin 1 on under the steering wheel column is dead (which is comming from Fuse #1 in the PDC).
So there must be a splice along the way which is feeding ignition switch C2 as you mentioned but you did say this was done in the fuse box?
Any diagrams would be useful! I have the 2002 diagram here. It does show it going to C2 (#16 10A) but the diagram says "Not used" - it could well be used on the 2004 Diesel model!
Thanks
Old 25 Jan 2013, 06:29 pm
Yes it is a Diesel.
Thanks
Ok,my shop manual shows on the 'Diesel',fuse 1 to S123 {in PDC} 14g RD.
fuse 3 to ign.switch 12g PK/BK.
fuse 4 to fuse block 14g DB.
Old 26 Jan 2013, 07:44 pm
Look for a 150 amp mega fuse below the passenger seat. It is inline between the battery and the PDC.
Yes it is a Diesel.
Thanks
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
Ignition kill switch Jtwheels2007 Sound and Security Forum 8 18 Sep 2012 09:41 am
Ignition Switch BMAC1206 General PT Cruiser Discussions 10 22 May 2012 03:27 pm
Ignition Switch??? Don162 Tech & Performance Forum 2 19 Aug 2009 11:03 am
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
