starter replacement
Old 25 Jan 2013, 01:58 pm
Default starter replacement
Does anyone have a GOOD description (with pis) of replacing the starter on a 2003 PT with oout turbo?
Old 26 Jan 2013, 03:13 pm
Default Re: starter replacement
Watching the movie is like watching a dancer's eyes to learn how to dance.
Really, I need t know how you're supposed to remove the structural collar.
Just commenting that "Just remove the 5 bolts, and it will fall out" isn't sufficient. Any tips?
Old 26 Jan 2013, 05:00 pm
Hey CREWZIN is that u-tube video suppose to be a joke hehe. No way your getting under my GT to change out a starter with the front wheels on the ground.
Old 26 Jan 2013, 08:54 pm
That video is part 1 Not PT 1 this a truck.
Old 26 Jan 2013, 11:24 pm
Here is exactly what the haynes manual says :-D Gonna take a while to type this all out, so you better appreciate it haha
1. Detatch the cable from the negative terminal of the battery.
2.Raise the front of the vehicle and place it securly on jack stands.
3. Remove the engine structural collar. *this is the illustration in the manual*
4. Disconnect electrical connectors from the starter/solenoid assembly *again the illustration from the manual which states "to detach the starter motor assembly, remove this bolt from the bellhousing side (dont forget to reattach the ground wire when installing the starter)*
5.Remove the starter mounting bolts *another illustration*
6.Lower the starter motor assembly from the engine compartment.
7.Installation is the reverse of removal, be sure to tighten the starter mounting bolts and the structural collar bolts securely.
Sorry for the low quality of the photos, my iphone sucks :-p
Old 15 Mar 2013, 02:14 pm
not so sure on how similar they are, but i just did my 05 pt non turbo. it was simple. check out my thread "i think its the starter"
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
starter? jmikesch General PT Cruiser Discussions 5 07 Jan 2012 02:15 pm
Bad starter?? jdmickies Tech & Performance Forum 8 06 Sep 2010 11:01 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
