Batteries and cables
Old 25 Jan 2013, 06:30 pm
jollyjeepers's Avatar
Send a message via Skype™ to jollyjeepers
Default Batteries and cables
I've been reading about batteries and references to a "big three" mod, which I have yet to find as it doesn't come up in the search.
I have a 2005 non-turbo. I've been waiting for a couple of years for the battery to fail and normally test it once a year. Batteries don't normally have a very long lifespan in my experience.
The other day it seemed just slightly slower to start. We are not having bitterly cold weather and yesterday it was in the single digits and did not start for the first time ever. No battery light has ever come on, but I think it's time.
I've read the instructions for how to get the battery out. I will probably purchase from AutoZone or Advance depending on price.
I would assume that the "big three" mod is relating to replacing battery cables. Can you provide me a link to a thread on this? Any other words of wisdom or advice? I generally like to do things proactively and replace anything while I'm in an area.
I have still be wanting to put a cold air intake on this car, but haven't decided which one to get so it has the stock intake on it presently.
Thanks!
Beth
Old 25 Jan 2013, 06:47 pm
cruserdad1976's Avatar
Default Re: Batteries and cables
no I think the Big 3 is refering to steros and adding mosr power to drive them monster speakers and the power amps they run if you dont ahve a big battery and a high output altenator and some big wires you will get your lights flickering when the amps push the killer bass notes
changing the battery is simple the tie down the termainal and you are out
Old 25 Jan 2013, 06:52 pm
Ray_Dockrey's Avatar
Here you go. And it is about the cables.
big 3 upgrade
BIG 3 -
Old 25 Jan 2013, 07:18 pm
That's great. Thanks for the info. I have no high tech accessories, but I'm glad to know about it.
Old 25 Jan 2013, 07:50 pm
It's a good possibility your cable ends were needing cleaned. Cold weather will find this fault as well as a weak battery. These need to be looked at at a regular intervals. Battery can get a charge if the ends are dirty.
Old 25 Jan 2013, 07:57 pm
You are absolutely right. I will inspect when it warms up in a few days. I also have plenty of those little felt pads that my husband must have bought a case of that I can use when I reattach my battery or install a new one.
Thanks!
Beth
Roanoke, VA
2005 PT Cruiser "Peyton"
Base 5-Speed
Diamond Back White Walls
Single Bar Flipper Caps
Wheel well trim
Custom Paint accents
K & N Air Filters and synthetic oil always
Old 25 Jan 2013, 09:33 pm
Thanks!
Your welcom. I find if I rub a little ignition grease on the post after I clean them I don't need to worry with it for a year or so. I usually find I'm there for something else before I have a starting issue. So I just do it then.
Old 06 Feb 2013, 08:36 am
Well, the end result was that my negative terminal was badly corroded, but my battery tested bad though it did have a full charge so the alternator was doing its job.
I like Autozone better than Advance so got them to price match the coupon that was listed elsewhere here.
I cleaned the terminal and added a coating to prevent corrosion and the little felt-like pads around the battery posts. I had these in stock so no out of pocket expense. I'll check the terminals when I clean my K & N filter for regular maintenance in the future.
I'm impressed that the factory battery lasted for almost 8 years.
Beth
Roanoke, VA
Base 5-Speed
Wheel well trim
Old 06 Feb 2013, 08:42 am
You ought to be. Some fail after 3 years!
Old 06 Feb 2013, 10:30 am
Like mine! Mine still tests good, but the cold cranking amps are low and it turns over pretty slow in the morning. I've got a couple more weeks left on my basic warranty, so I might see if I can squeeze in a new one. It tests good, though, so I'm not sure if I can get away with it!
-Chris
What's with AutoCraft Batteries compdr59 Tech & Performance Forum 1 04 Jan 2013 11:03 pm
Canbus/250 miliamp draw/dead batteries! Busa_Powered Sound and Security Forum 8 12 Aug 2012 02:24 pm
Do these things run on 9V batteries? damilleniumboy General PT Cruiser Discussions 21 10 Oct 2008 05:16 pm
MOPAR Batteries convert to Interstate Batteries! Wicked_PT PT Cruiser News and Rumors 1 29 Jan 2006 01:26 am
Advice on Alternator and Batteries PT Lilly General PT Cruiser Discussions 1 11 Jun 2005 12:25 pm
