ASD or SKIM Startup issue
  • 1 Post By Fuzzyweis
Old 25 Jan 2013, 09:29 pm
Fuzzyweis's Avatar
Default ASD or SKIM Startup issue
So, I've got most the gremlins out of my 2008 pre-owned Cruiser, camshaft position sensor replaced, ignition switch replaced. But there's still one niggling little issue left.
Occasionally, it will start, rev up to idle, and then shut down, does this 3 times, then doesn't even turn over. I pop the ASD fuse cartridge on the fuse box, wait a few seconds, pop it back in, car starts right up.
So obviously, the ASD circuit is being tripped, but can that be caused by a faulty SKIM? I'm not sure as I think I wouldn't be able to reset it.
And if it's the SKIM, could it just be my key? The wife hasn't had it happen with her key, but she only drives the car 1/5th what I do, so could just be luck of the draw.
If it's not the SKIM, am I probably looking at the whole computer? Cause I can live with just resetting the fuse on occasion, maybe even wire in a reset button to the dash to make it easier.
Thanks in advance.
-Jim
Old 25 Jan 2013, 09:45 pm
Default Re: ASD or SKIM Startup issue
Thanks in advance.
I would use the one key only and see if that one ever dose it. I didn't say trade the wife keys because she would be mad if it dose it to her with your key.
If it reaccours then I would suspect the ingnition switch area were it detects the key.
Old 25 Jan 2013, 09:56 pm
Fuzzyweis's Avatar
Yeah, forgot to mention I wasn't planning to swap keys with the wife, I would not enjoy getting that phone call
If it doesn't happen with her key then I guess it's mine, which sadly cost almost as much as a SKIM module.
Busted_PT likes this.
-Jim
Where is the SKIM module? BarbMc Tech & Performance Forum 9 09 Jul 2013 01:04 am
SKIM Woes wirelessdog Sound and Security Forum 4 14 Jul 2012 08:54 pm
Fried PCM/ECU? SKIM? Need some leads jdpersico General PT Cruiser Discussions 19 09 Jul 2012 03:23 pm
SKIM 99PlyNeon General PT Cruiser Discussions 0 30 Jul 2011 08:01 pm
SKIM Fault? hobbit Tech & Performance Forum 20 28 Apr 2010 04:27 am
