gas leaks at 3/4 tank and code 0442
Old 26 Jan 2013, 04:15 pm
Default gas leaks at 3/4 tank and code 0442
I've dropped the tank a few times to look for a leak and it seems to be coming from the "plug" on the back of the tank. Is this plug anything more then a drain plug? I removed it and sealed it with grease around the seal and code went away and no gas leaks for a few weeks. Question being what happens if I permanently seal this plug? I was thinking of JB welding/sealing it. It didn't seem to have any problems when I used grease to seal it.
Old 27 Jan 2013, 07:51 pm
Default Re: gas leaks at 3/4 tank and code 0442
Here is a picture of the "plug" and all that lovely Ohio salt.
Old 27 Jan 2013, 08:27 pm
If you seal it use silicone, more flexible. But the gas streaks look like they go around the filler tube as well?
Old 27 Jan 2013, 08:33 pm
Probably from the last time I dropped the tank. The marks were just from that plug. I thought about silicone but I think its just gas resistant and not "gas proof" I didn't want it degraded and getting into the fuel system.
Old 27 Jan 2013, 08:46 pm
Find out what the exact purpose of the "plug" is before you seal it up...the venting and evap system on these tanks is a bit complicated...make sure that it is meant to be sealed up and not some kind of a check valve.
Old 27 Jan 2013, 08:50 pm
That's what Im hoping to find out. I put grease around it and it sealed no leaks or check engine light. Then as the grease diluted with the gas the light came back on and the leak is there
Old 28 Jan 2013, 02:27 am
There wouldn't be a vent that low. But this could be a test port for the evap system. What about a new cap. Maybe a seal is bad?
Old 15 Sep 2013, 04:44 am
My plug is leaking also do you know what it is and if you can replace it
Old 17 Sep 2013, 05:33 pm
fy9-03pt's Avatar
GO to home depot and see if they have the Pink teflon tape and try that. or permatex sealant.
Robert
Old 21 Sep 2013, 12:19 am
Stan; look up the plug/cap in the parts manual available on this site. It's free! Permatex makes a gas tank/radiator sealer I just saw on another thread. Sounds good on paper.
oil leaks fancy Tech & Performance Forum 5 29 Oct 2011 07:48 pm
Error Codes 0522 and 0442 logicalfrank Tech & Performance Forum 3 01 Apr 2010 11:57 am
P0452 Fuel Tank Pressure Sensor Error Code dornstar Tech & Performance Forum 0 22 Aug 2007 12:08 am
UGH! Code 0442, PT Cruiser 2001 LTD, 41,000 miles tvldeals General PT Cruiser Discussions 5 08 Aug 2005 12:46 am
Code 0442 on my PT 2001 LTD, 41, 0000 miles.!!!!! tvldeals Tech & Performance Forum 3 06 Aug 2005 09:57 pm
