Explain the 01's PCV hose to me...please.
Old 27 Jan 2013, 03:43 pm
JenneK's Avatar
Default Explain the 01's PCV hose to me...please.
My 01 NA has two hoses coming from the valve cover. The one on the front right is the PCV and seems to have the valve that screws into the cover.
There is one on the back side with no such valve that connects straight to the flexible intake tube. What's up with that one? Why no check valve or anything? It's oily in there. It gets my throttle body oily and screws up my idle. It also makes a puff of smoke come from my exhaust at start up under certain condition. Me no likey. I've read where that's "common" on the 01's.
Can I plug it and the intake tube? Is there a better "fix"? Is that tube there on subsequent models?
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 27 Jan 2013, 05:24 pm
Default Re: Explain the 01's PCV hose to me...please.
I'm not sure why the second tube/vacuum line that's connected to the flexible intake is oily? Mine is dry as a bone. Not a drop of oil inside the line or at either end. I'm not sure of it's purpose except it might be taking some of the gases/fumes from under the valve cover and it's being sucked into the intake where it's burned. Maybe something to do with the emissions.
If yours is oily and making your throttle body oily, you have something wrong. Have you changed your PCV valve lately?
Old 27 Jan 2013, 05:39 pm
I can't find where I already gave a technical response pertaining to PCV system. maybe CREWZIN can find it?
In short, No you can not plug the valve side of the PCV system or air filter hose because of crankcase pressure. Yes you can bypass the complete system running without a PCV valve. but this must be done correctly and it will not meet emission regulations. If oil is on present in either hoses but seen mostly on the air filter side you it is a sign of engine wear either rings or valve guides.
Old 27 Jan 2013, 07:43 pm
Somewhere on here they speak of a catch can mod that caught the oil. Hose runs into it and out to the intake hose or air box.
Old 27 Jan 2013, 08:52 pm
Theres really only 3 ways for oil to get into the upper manifold.
1 through the air cleaner, up into the throttle body *a dirty throttle body can spit oil into the upper intake easily*
2. The PVC valve being stuck in the open position *remove it and shake it, if you cant hear the bearing bounce around, its time to replace*
And through the lower intake *sometimes the seals around this have oil, but if theres a LOT of oil near these seals, you have bigger issues*
I would start by removing the upper manifold, and looking inside with a flashlight
There is a TON of air being moved through this so any oil residue inside should leave a visible grease mark either from the throttle body, from the other end of the PVC hose or from the lower manifold upwards. Take a look inside and see what you can see, if that doesnt pan out, check your PVC valve, check the throttle body and check around the lower seals on the upper manifold :-D should get a pretty good idea of whats going on :-)
My guess is its the PVC if that is clogged the motor will blow oil out of the weakest point in the motor so, a $6 part may fix this :-D
Old 28 Jan 2013, 02:03 pm
UptownSport's Avatar
There's an interval for replacing PCV-
I worry that spring corrodes or valve accumulates sediment- making calibration off-
in short, replace PCV!!!!!
Valvecovers separate (as best they can) liquid from crankcase air thru labyrinths under an aluminum plate (on PT). Labyrinths have needed to be resealed (early 2.2).
Valve cover MAY be improved for a better labyrinth. PT did have a valve cover change early on.
Why?
Cosmetics?
Added boss?
Labyrinth improvement?
I don't know
Most liquid that PCV passes is water, a separator will collect lots of it.
Oil in intake isn't unusual in an old/high mileage vehicle, or even newer ones- If ring seal is lacking in one spot, you'll get blow-by.
It doesn't look good, but doesn't hurt anything.
in short here, don't try to fix what isn't broken!!!
You can see spectacular blow-by when dudes put on the nifty turbo kit an a Neon (or any) engine and don't add enough fuel- engine cracks piston and adds pressure beyond PCV design
Old 02 Feb 2013, 12:46 am
JenneK's Avatar
Thanks for all the responses.
As usual I went off all half cocked. My brain just wasn't working... The PCV was in need of a cleaning...or at least that's what fixed the issue. Here I was ready to rework the entire emission system just to fix a simple issue.
Thanks for pointing me on the straight path.
Old 02 Feb 2013, 11:13 am
2step's Avatar
Here's a cut-away drawing that shows how a PCV valve works. (Notice the size of the "arrows" and the flow direction)
Different driving styles cause more or less crankcase vapors to escape through the second hose to the intake pipe/air box.
Old 02 Feb 2013, 01:58 pm
Where do these arrows come from, and do they hurt my engine?
been done before
Someone explain the warranty situation! alexatanes General PT Cruiser Discussions 6 14 Nov 2008 10:39 pm
Trying to explain "the sound"... blucrsr Wheels, Tires, Suspension 12 10 Aug 2005 07:31 am
Buy now explain later policy? stirfry General PT Cruiser Discussions 24 28 Apr 2004 04:51 pm
Explain tire sizing cruisergeo Turbo Wheels/Suspension/Handling 13 28 May 2003 07:40 pm
