help 03 gt needs motor
Old 27 Jan 2013, 08:37 pm
Default help 03 gt needs motor
my 03 needs a motor Will a 2004 gt turbo motor work? Anything I will need to change to make it work
Old 27 Jan 2013, 09:24 pm
TurboDucky's Avatar
Default Re: help 03 gt needs motor
'03 through '05 are exactly the same. As is the SRT-4 motor. What's wrong with your current engine?
-Gary-
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 28 Jan 2013, 02:01 am
Times 2 on that!
Old 26 Feb 2014, 11:18 am
does this apply to my question as well? thank you in advance for your reply. mine is a 2003,can get a 2004 motor but was told that there was a wiring problem?
Old 26 Feb 2014, 12:55 pm
TurboDucky's Avatar
Yes it applies - '03 to '05 were the same engine.
What's wrong with your existing engine?
-Gary-
Old 26 Feb 2014, 12:58 pm
As long as you are changing a turbo for a turbo or n/a for n/a your good. Will need to change fuel injectors if it's a turbo. Jus use your old intake lower. Also change out any sensors that don't match your plugs on your harness. I would change out the timing belt and water pump while it's out. Just me. If it's a turbo throw a $35. Kit in that to. You will be good to go.
New motor jaypee Tech & Performance Forum 2 25 Nov 2012 06:32 pm
how old is the 2.4 motor crazyptguy Tech & Performance Forum 4 24 Feb 2012 02:34 am
05 Gt motor into 03 GT Coopsta454 General Turbo Discussions 1 23 Nov 2010 03:17 pm
Which Motor Oil PTNoob01695 General PT Cruiser Discussions 18 24 Aug 2009 08:42 pm
fan motor rrrperry Tech & Performance Forum 3 31 Aug 2004 09:06 pm
