Free 01-04 PT cruiser shop manual
Like Tree37Likes
  #61 (permalink)
Old 29 Feb 2016, 10:47 pm
WrenchnIswhatIdo's Avatar
Default Re: Free 01-04 PT cruiser shop manual
Originally Posted by ptdog View Post
Ok. Here we go. A lot of people have been searching for a shop manual for the 01-04 PT. Well I found one at: 01-04CPTC.pdf. It's a PDF download without all the ads and other hoops you have to jump through. .
Thanks so much a Big help Links work.....W
  #62 (permalink)
Old 13 Jun 2016, 11:03 pm
THANKS!! I could not figure out how to remove the high side AC switch. I downloaded the manual and found it right away!!
  #63 (permalink)
Old 07 Jul 2016, 07:54 pm
Smile Re: Free 01-04 PT cruiser shop manual
First I would like to say Hello to every one here. Just joined tonight. To make a long story short, I have a 2002 PT Cruiser LTD and currently involved in some electric problems with same. But thanks to the humongous amount of information here I think I have it solved. (Only time will tell).
Ok. Here we go. A lot of people have been searching for a shop manual for the 01-04 PT. Well I found one at: 01-04CPTC.pdf. It's a PDF download without all the ads and other hoops you have to jump through. Just trying to give something back. Hope you can use it and thanks again for all the information.
I am old and am going to gum some dinner.
Thanks man!! :-)
  #64 (permalink)
Old 28 Apr 2017, 10:23 am
This manual does not cover 2001-2002 PTC.
The crankshaft sensor is shown in different (later models) spot and unless I missed it, the EGR system is not shown at all.
2001 PT Cruiser Limited Edition 5-Speed MT, stock. Second owner since 06/2016
  #65 (permalink)
Old 28 Apr 2017, 11:07 am
Your right about the Crankshaft sensor which shows it under the starter instead of above the oil filter. There's no pictures but the EGR system is covered in chapter 25 (Emission Control). Who ever put the manual together probably did it around 2004 and took it that the sensor and EGR pipe (missing in 2003/04) were the same for earlier models.
Early model PT had Crankshaft Senor on top of the oil filter at the rear of the engine. Later it was moved underneath of the starter.
Early model EGR pipe at the rear of the upper manifold. Two different size bolts (8mm & 13mm)
Handy_Cruiser likes this.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
  #66 (permalink)
Old 20 May 2017, 01:38 pm
I got the manual. Works good.
rckstein likes this.
  #67 (permalink)
Old 20 May 2017, 02:05 pm
Glad it's still working. Thanks for the feedback.
  #68 (permalink)
Old 28 Jan 2018, 04:05 am
Evgenij's Avatar
Unfortunately, the links to the documents for a car 2000-2004 and 2005 are not working. Is it possible to upload this documents again? Thank you in advance.
  #69 (permalink)
Old 28 Jan 2018, 08:39 am
rckstein's Avatar
I sent you a PM with a link where you can download a copy of the manual from my DropBox.
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
  #70 (permalink)
Old 28 Jan 2018, 02:17 pm
Evgenij's Avatar
Thumbs up Re: Free 01-04 PT cruiser shop manual
Rick, many thanks for your fast and comprehensive help again!
Do you have also the service Manual for PT2005?
Can you help me find him? My best regards.
Tags
pt cruiser 2002, shop manual
2006 PT Cruiser Looking For Free Repair Manual Camaron32 Tech & Performance Forum 17 31 May 2017 05:58 pm
Shop manual? nitram01 Welcome New PT Cruiser Members 5 21 Sep 2011 01:42 am
2004 Shop Manual harry Classifieds: Want To Buy 3 24 May 2010 04:13 am
Shop Manual (service manual) DEEFIEND Tech & Performance Forum 2 17 Jan 2008 07:55 am
OEM shop manual zoned General PT Cruiser Discussions 6 10 Nov 2004 02:16 am
