Instrument Cluster Dead & No Start
Old 28 Jan 2013, 11:13 am
Default Instrument Cluster Dead & No Start
Hi,
I have a PT Cruiser 2004 Diesel model.
The instrument cluster has no lights on it and no activity at all, I have checked all the pins on the connector and the correct ones are getting all the correct voltages and the grounds look good.
The starter relay does not even try to fire, however there is power going to the common pin on the relay.
I tried hooking up a bit of wire in place of the relay and it trys to start the starter motor.
Does anyone know what could be causing this? Is it likely to be a wiring issue or perhaps dead Powertrain Module?
Thanks
Old 28 Jan 2013, 02:02 pm
Default Re: Instrument Cluster Dead & No Start
Bad ignition switch perhaps...???
Old 28 Jan 2013, 02:25 pm
sanatanadharma's Avatar
Do you have the shop manual?
The diesel wiring schematics can be found here:
Free 01-04 PT cruiser shop manual
Reading your various posts, I am stumped. If the PDC starter relay is not faulty, the powertrain module is likely the problem. The starter relay is grounded through the ECU when the computer gets "go" signals from all sensors. One of those sensor circuits can be bad (like signals from clutch or neutral switches).
Originally Posted by nickcruiser View Post
Hi,
The instrument cluster has no lights on it and no activity at all, I have checked all the pins on the connector and the correct ones are getting all the correct voltages and the grounds look good....
Thanks
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Could it just be the instrument cluster? ukbeachbum General PT Cruiser Discussions 21 17 Sep 2015 08:50 pm
Instrument cluster goes dead kwells44 Tech & Performance Forum 5 02 Dec 2012 06:08 pm
Instrument Cluster Replacement JohnBrehm Tech & Performance Forum 10 17 Feb 2011 11:58 am
Dead Instrument Cluster JohnBrehm General PT Cruiser Discussions 0 09 Jan 2011 10:16 pm
Instrument Cluster Lens rszappa1 Interior Accessories Forum 5 30 Jul 2004 09:10 pm
