Help my baby( a 2001 pt cruiser) please
Old 29 Jan 2013, 12:18 am
Default Help my baby( a 2001 pt cruiser) please
Ok so my 2001 pt cruiser has began to over heat. I took it to Chrysler and they said it is happening because of an accident I was in a year a go. My boyfriend and his friend ( they work on engines) said the radiator has a hole in it. But yet the guy at Chrysler said that it was some things got crushed cause of the accident. And it would cost over a grand to fix it all not to mention the body shop work not included. I've taken this car recently to my mechanic who put in a new water pump changed the timing belt and the spark plugs last month ( he said nothin bout everything being crushed.) what should I do? I am going to try to attach a pic of the dent in the post below.
Old 29 Jan 2013, 12:23 am
Default Re: Help my baby( a 2001 pt cruiser) please
It's not leaking any coolant or anything. I need an oil change and I think the wrong coolant was put in the car( when the water pump and belt was changed)
Old 29 Jan 2013, 12:47 am
Originally Posted by chefbunnyk View Post
Ok so my 2001 pt cruiser has began to over heat. .................. My boyfriend and his friend ( they work on engines) said the radiator has a hole in it. ............................
^^^^^^^^conflicting ????^^^^^^^^^^^^^
First have a pressure test done on the cooling system.
If there is in fact a hole then change the radiator, thermostat and drain refill your cooling system. Then see what happens?
The wrong (?) coolant if you live in and purchased it US is not going to cause heating issues as long as it was no more then a 50% mix.
Old 29 Jan 2013, 01:07 am
Lightbulb Re: Help my baby( a 2001 pt cruiser) please
Your baby is missing a plastic simulated lug nut on your hubcap too
Old 29 Jan 2013, 01:13 am
Exclamation Re: Help my baby( a 2001 pt cruiser) please
Like the New signature line there nitro, cheers on the cheerybomb.
Old 29 Jan 2013, 01:21 am
You noticed my new signature (good eye) but never noticed the exhaust that had (past tense) been around on my PT and pictured since summer? I just didn't really make it known because I used spare parts I had to make the system up.
Old 29 Jan 2013, 01:28 am
Nope I didn't......
So you have your side skirts "permanently" installed now too?
Old 29 Jan 2013, 01:33 am
Nope I didn't......
Nope! I have parts all over the garage and house that have not found there way on the PT yet!
You should look at my thread once in a while and see what is going on?
Old 29 Jan 2013, 01:51 am
cruserdad1976's Avatar
unless i missed something this is nto near the radiator
yes it could ahve a leak they do that some times
a radiator from Oriley is $149 you have some one to do the work
my question is how hot have you got the car??? above the red line into the red or just above the half way mark
my guess is your radiator fan has died they are cheap like $100 at rock auto and not to hard to install
Busted_PT likes this.
Old 29 Jan 2013, 06:06 am
mnahmnah's Avatar
Hard to know without checking out the car. But check out the PT coolant thread here (your radiator could be gunked up?)
Why HOAT? The PT radiator coolant thread...
Also, there are two fan fuses located under the hood near the positive battery terminal (the one by the brake fluid reservoir). One is for a high fan setting and the other is a low fan setting. One may be bad. One costs more than the other but I think they are each under twenty bucks. Might want to check there first. Don't spend a grand and don't panic!
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
help my baby blue (pt cruiser)wont start!!!! pttapp Tech & Performance Forum 2 12 Apr 2010 02:53 pm
lookin for inexpensive bra and smokers kit for my new baby... 2006 PT Cruiser truckdrver1974 Canada PT Forum 7 14 Sep 2009 01:25 am
My other baby careyk General PT Cruiser Discussions 4 08 Jun 2008 06:57 pm
My New Car Baby! skylight PT Cruiser Videos 0 28 May 2008 07:39 pm
PT Cruiser: Nobody's Baby skylight PT Cruiser News and Rumors 1 15 May 2007 02:39 pm
