ABS & Trac lights ON
Old 29 Jan 2013, 10:23 am
Unhappy ABS & Trac lights ON
Hi
I have a PTS Cruiser Ltd CRD 2005
I have the ABS and Trac lights on all the time - dealer says faulty rear O/S sensor (65 for scan). Changed sensor myself (55). Lights still on. Tried to clear fault by disconnecting battery for 20 mins, no luck so went back to dealer for reset. Dealer says they can't reset as there is a sensor wiring fault? Anyone else have this problem? Is it easy to replace the wire? and does anyone know the routing for this cable. Help would be appreciated
Thanks
Old 29 Jan 2013, 12:13 pm
Default Re: ABS & Trac lights ON
We've seen that problem before. Especially look at the second link as there's more links about the problem to check out.
ABS and Traction control warning lights on
abs/trac warning light
Old 29 Jan 2013, 01:31 pm
Thanks for the prompt reply Crewzin
My problem tho is trying to detect and repair the broken cable and dont know where it is routed. Will have a look tomorrow, weather here in uk not too good at moment. Dont suppose there is a drawing anywhere showing the cable route from O/S rear. Is it possible to get a replacement cable from the ABS unit to the rear of car? or do i need to make a new one using the existing plugs?
Old 29 Jan 2013, 01:56 pm
When I got my cruiser it sat up for a few years. When I started driving it those lights popped up, But the car still drove and stopped normal. After about 6 hours of driving maybe less it just went off and hasnt returned.
Old 29 Jan 2013, 02:14 pm
I wouldn't believe you'd need to replace the whole cable but anyway, the repair manual doesn't show the whole routing of the cable. Just the parts at the wheels and under the hood.
Old 07 Feb 2013, 10:59 pm
Managed to get it sorted : FYI the cable from the rear wheel sensor runs underneath the car and up into the engine compartment where there is another connector. the fault was an open circuit in the engine compartment wiring loom. Its difficult to get at and i had to run a new 2 core cable cable.
After fixing i had to get dealer to clear fault, how crazy's that ? THE ALTERNATIVE is to switch the ignition ON/OFF 255 times or drive 3500miles ?
Abs and trac lights on Denvercruiser General PT Cruiser Discussions 50 28 Nov 2016 06:28 pm
Engine, ABS and Trac Lights on - Garage reorted no error codes AndyJay Tech & Performance Forum 15 03 Apr 2014 12:43 pm
Swapped my PT, but have a new problem... ABS & TRAC OFF Lights on.... stek2008 General PT Cruiser Discussions 7 16 Dec 2010 08:27 am
Trac Off HLeyes Interior Accessories Forum 3 15 Sep 2008 05:52 pm
TRAC system shodobe Tech & Performance Forum 2 31 May 2005 07:58 am
