Need help figuring out what's wrong with this car!
Old 30 Jan 2013, 02:42 am
Default Need help figuring out what's wrong with this car!
My husband has a 2001 pt cruiser touring addition.156055k miles and hes had it about 1 yr.In the beginning the car ran fine,but the last 6months or so he's had nothing but issues with it.It will literally stop buck and not want to move then buck and run.Its been seen by the dealer(its financed)numerous times and they have replaced the tranny seal twice.The car now revs,kicks in then drives.Are the dealers missing something?He also had the motor mount replaced.The car is going back in tomorrow to be looked at yet again and I wanna see if someone on here has suggestions as to something they should be looking at.
Old 31 Jan 2013, 12:37 pm
Default Re: Need help figuring out what's wrong with this car!
Could be a fuel starvation problem, or transaxle problem. Keep pestering them till they get it right. They should have the tools to diagnose what's wrong. They just need the expertise to use them.
Old 31 Jan 2013, 04:46 pm
Failing fuel pump.
Slipping transmission (maybe wrong fluid???).
Old 01 Feb 2013, 02:26 pm
UptownSport's Avatar
Originally Posted by Carl48 View Post
Slipping transmission .
Sounds like it's slow engagement.
**** WARNING **** ALL THAT FOLLOWS IS FROM A GUY WHO HASNT DONE AUTO TRANS IN TWO AND A HALF DECADES (and prolly had no idea what he was doing then)
Time it takes for trans to engage is how long fluid pressure takes to make clutch(es) engage-
Obvious things should be ruled out (see owner's manual for maintenance schedule, capacities and specifications)
Then, ASK THEM TO PUT A GAUGE on the port(s), then report exact readings.
Although auto trans are very sophisticated machines, this is a procedure you could do yourself, given
1. gauge(s)
2. Factory Service manual (aka 'FSM') (Crewzin has it stickied)
3. Common hand tools (sears)
FSM has a troubleshooting guide for this situation, take some time to read it, you may not understand exactly what they're saying, but you will have indefinitely better understanding
Last, convert to the manual- Your life will improve by 11.2%
Old 01 Feb 2013, 05:15 pm
Unhappy Re: Need help figuring out what's wrong with this car!
Be sure to come back and keep us updated.
Too often people join for advice and never come back
Old 06 Feb 2013, 11:01 pm
Car went in last Thursday and I got a call it was a Tranny Leak and they needed to send it to a Tranny shop which they did on Friday.Talked to the owner of the dealership and she said its still in the Tranny shop because it is the Tranny and left it like that.I have no further update on the car,when I get one i will let ya know.
Old 09 Feb 2013, 05:25 pm
Finally got the car back on Friday.They told hubby it was a solenoid seal,but im not so sure about that.
Old 09 Feb 2013, 05:50 pm
Hopefully this was a inexpensive repair.
Old 13 Feb 2013, 02:13 am
amarine1's Avatar
Most likely, it was the "Solenoid Pack" (which means the tranny was leaking). It sits on the outside of the tranny. This is common for most Chrysler tranny's (I've aleady replaced the Solenoid Pack itself or the seal on both the 2001 Town and Country and the 2003 Sebring Convertible).
The average cost is $120 for the seal (parts and labor) or $220 for the Solenoid Pack itself and seal (parts and labor)... using a local mechanic. Double the cost if going to a Chrysler Dealership.
2008 Chrysler Sebring Touring (metallic silver) H/T, 88,000 miles (2nd owner).
2005 Chrysler PT Cruiser Touring Convertible (Off White) 107,300 miles (2nd owner - 2.4 Turbo engine).
2009 Toyota Sienna Mobility Minivan, 28,500 miles (2nd owner ).
E-4 USMC 1981-1988 - Motor T - Honorable
HELP!! Codes and figuring out the fix BlueInGA Tech & Performance Forum 19 06 Jun 2012 07:36 pm
Maybe im wrong 2010ptfreak Wheels, Tires, Suspension 8 09 Nov 2011 04:10 pm
What did I do wrong? sniggle Wheels, Tires, Suspension 5 28 Jun 2011 09:09 pm
Figuring out my 2006 TE (help!) cruisinbabe General PT Cruiser Discussions 5 13 Oct 2007 08:14 pm
