Electrical issue need help!
  • 1 Post By jcraft
Old 31 Jan 2013, 09:11 pm
Default Electrical issue need help!
Hi all,
New to the forum. Have a 2002 pt cruiser with 39,000 miles. Over the years it has been plagued by a few electrical issues that seem to crop up every few years. Here is the latest. Got in the vehicle this morning started up and noticed these items wrong right away. I drove vehicle last night and these were all working correctly. First the blower motor for the heater does not turn on at all in any position. Two, none of the electric windows will work and one of the led's on one of the buttons is out. Third, the rear defroster will not work ( at least when you push button the led does not light. And last the air bag dash light is lit. As stated all this worked yesterday. I haven't had a chance to dig deep, but picking the blower motor I found the fuse in the box and it was good. I have the schematics in the repair book and it is all a bit confusing. looks like the windows are fed from a C.B. and the blower from a fuse. I was hoping it would be a common fuse to all. The schematic shows them both these protection devices from RUN-A22 whatever that is. If anyone knows the layout of the power side and how it is routed let me know. Thanks
Old 31 Jan 2013, 10:10 pm
Default Re: Electrical issue need help!
As far as I can see, the RUN A22 is part of the interior fuse block and we have seen several owners have problems related to that fuse box. Burnt wires and bad connections. I'd start by taking the cover off the fuse box. You'll find 2 Phillips head screws that hold the panel with the fuses and a couple CB's. take that out and inspect the harness and connections behind the panel.
Old 31 Jan 2013, 11:23 pm
sanatanadharma's Avatar
Check fuse # 3 (40amp) in the PDC under hood. It protects the Run A22 circuit.
Originally Posted by CREWZIN View Post
As far as I can see, the RUN A22 is part of the interior fuse block and we have seen several owners have problems related to that fuse box. Burnt wires and bad connections. ...
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 01 Feb 2013, 12:03 am
Cool Re: Electrical issue need help!
Wow, we can't blame the canbus this time! Lol
Old 01 Feb 2013, 07:13 am
THanks guys,
I did find the following. There is a large plastic connector under the dash behind the fusebox. There is probably 20 wires coming out of connector. I'll bet it is the fuseblock circuits. I wiggled several wires at the connector and the connector itself and presto everything came on and worked. I did have this issue quite a few years ago with intermittant door lock and fog lamp issues. I found a corroded wire into this connector. HAd to resplice and jump around connector. I bet I'll have to do the same here. It is in an awkward spot so hopefully I can find the right wire.
Old 01 Feb 2013, 07:17 am
Glad you found it. Good luck on the repair.
Electrical issue driver side REAR darin Canada PT Forum 0 03 Oct 2012 06:15 am
Electrical issue? DMod General PT Cruiser Discussions 38 23 Jan 2012 08:49 pm
04 Electrical Issue jjackson23 General PT Cruiser Discussions 11 19 Aug 2011 10:55 pm
Electrical Issue bham Tech & Performance Forum 1 15 Jul 2011 01:00 pm
07 Fan/electrical issue? megamatt77 Tech & Performance Forum 2 23 Jun 2010 03:38 pm
