Brake Pad Differences???
Old 01 Feb 2013, 01:10 am
Default Brake Pad Differences???
Is there any real performance, durability or longevity issues with Ceramic vs Semi-Metallic? Keep in mind you are talking to an Old School V8 Guy that misses Asbestos Brake Pads.
Old 01 Feb 2013, 04:31 am
Default Re: Brake Pad Differences???
Old school...go semi-metallic...you won't like the ceramic.
Old 01 Feb 2013, 04:50 am
Ray_Dockrey's Avatar
Here is some reading:
ceramic vs. semi-metallic brake pads
What front brake pads are people using?
Old 02 Feb 2013, 09:17 am
I never go cheap on brakes or tires - those are not things to go cheap on...
Old 02 Feb 2013, 09:55 am
compdr59's Avatar
I wasn't happy with a set of Wagner Thermo quiet semi metallic. Whenever it was raining heavily braking was dicey. I had to return them for a set of semi-metalic brakes and rotors from Brakeperformance.com. I found them on this forum unused and now I can stop all the time.
I once put a set of ceramics on my RX-330 and I had no stopping power. I went back to semi-metalic.
IMO stick with semi-metalic.
Original Owner 135k
Old 02 Feb 2013, 12:13 pm
It is not about going cheap or the the type pads used, but rather what your driving environment is. It is very much the same as carefully choosing the tires you will be using. There is NO perfect brake pad and each type has specific operating advantages and disadvantages. If it were so easy there would not be over 200 choices in pads and shoes available on the market for PT Cruiser!!!
Even in old school 30+ years ago there were more options then most thought available so you needed to do your homework for the best option of brake pad/shoe material for what use your vehicle was.
I have 2 current BBK on the market and offer a choice of pads for different customer needs. When I built AC Cobra kits It was always a time consuming consultation with the customers to discus brake system and pad material options.
You can not compare brake material performance recommendation from others unless you have the exact vehicle duplicated in running gear, suspension, the same level of driving experience and environment. This would be unsafe for both you and the other sharing the road around you.
what r differences carolinagirl General PT Cruiser Discussions 20 20 Jul 2011 09:39 pm
differences between engines ptguy69 Tech & Performance Forum 1 23 Dec 2010 04:11 pm
PT Differences? 01-06 mjb457 General PT Cruiser Discussions 8 08 Jun 2006 01:50 pm
SRT4/GT differences hoopdiewagon General Turbo Discussions 10 25 May 2004 07:33 am
Model differences? daffy General PT Cruiser Discussions 2 19 May 2004 10:30 am
