Hahn Turbo Install Question
Old 02 Oct 2002, 02:26 am
Default Hahn Turbo Install Question
I'm in the midst of installing a Hahn Turbo in my 02 Cruiser.
I have run into a problem with the turbocharger itself. I notice three threaded ports on the body of the turbo, one port has a small hole at the bottom of it , so I assume that is for the oil in line?? The other two have nothing inside, just an open threaded hole. The instructions do not indicate what these other two ports are for nor are there any fittings or plugs for them. Should I just leave these ports open?
If anyone who has installed a Hahn turbo can help me out I would appreciate it. Thanks.
Old 02 Oct 2002, 09:26 pm
You might want to check the performance section of PTEnthusiasts, Bob Stockam has done extensive work with the Hahn turbo and can give you LOTS of good info.
2001 Aquamarine Touring - Mama's.....2002 Cranberry Touring - Mine
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
Hahn Racecraft Turbo??? PT PeZ Tech & Performance Forum 2 02 Oct 2003 10:16 pm
Turbo Timer Install Question gsharrock Turbo Performance 11 02 Jun 2003 07:35 am
Hahn turbo vs. Whipple Supercharger renichms Tech & Performance Forum 7 04 May 2002 02:40 pm
Hahn turbo install on 2001 automatic bstockum Tech & Performance Forum 0 06 Nov 2001 09:05 am
