My PT DIED WHILE DRIVING
Old 02 Feb 2013, 06:58 pm
Default My PT DIED WHILE DRIVING
Driving about 25 miles an hour and car died key turns but no crank
2001 limited at has 106k belt done about 10k ago. Lights work radio flashers windows dash light all power works. Just when you turn the key i get the chime but then nothing else. Lights dont dim no clicking. key just moves to start and thats all
Checked all fuses and relays changes ign switch componets and cranckshaft sensor andeven threw anew battery in for the hell of it.
Will crank if you cross the starter and timing belt is fine just wont start.
Ha too different people check with their diag tools and it wont communicate with the computer (PCM).
Is there a fuse before the computer (PCM) besides the ASD and is it possible to chk the computer before just buying one.
Thanks for the help
Old 02 Feb 2013, 07:24 pm
Default Re: My PT DIED WHILE DRIVING
for starters, as long as there's juice, do the key dance and see if any codes come up. there should be a sticky in the "how to" section for the key dance if you don't know how.
2016 Kia Soul Plus Black
Old 02 Feb 2013, 07:28 pm
no codes from the key and none from the scan tool
Old 02 Feb 2013, 07:33 pm
The directions for the "key dance" to get the fault codes is in the Tech & Performance section as a separate sticky all by itself near the top of the section. I didn't add it to the "How To" list.
How to retrieve fault codes.
On to your problem:
You said: "Will crank if you cross the starter"
If you look at the schematic below, between the ignition switch and the starter motor you have the PCM and the Engine Starter Motor Relay. I'd start with the relay. It's in the PDC (Power Distribution Control) in the engine compartment along with 6 other relays. All of witch can be swapped around for testing. There's also a Fusible Link but I'm not sure where that's located.
Relay "B" is is for the starter.
Old 02 Feb 2013, 07:50 pm
I would remove and clean every connection on the battery cables, from one end to the other.
Old 02 Feb 2013, 08:37 pm
The fusible link runs between the starter motor and the alternator...it is a dark green wire on my PT...you should be able to see it looking down at the starter motor, it attaches to the same terminal as the red positive battery cable. It protects the alternator and the electrical system from each other. Anyway, it has nothing to do with the OP's problem...look like his PCM may not be communicating.
Old 04 Feb 2013, 03:20 pm
I agree with this. While a bad starter relay could in fact cause the car not to crank without jumping the starter, it would not have killed the engine while driving.
It sounds like a PCM issue to me.
-Chris
Old 04 Feb 2013, 04:48 pm
I can say this. Was driving a car that shut off this way and wouldn't crank. A small wire on the solenoid had come in two. Spliced the wire and and fired and ran perfect. So I can't say myself if something similar could do this on a pt. This was before PCMs.
Old 06 Feb 2013, 08:00 am
I still wouldn't rule out ignition switch. They die more often than PCMs.
Old 06 Feb 2013, 01:31 pm
replaced the ign switch and actuator
Engine died while driving, now won't turn over. Need help finding problem ingram87 General PT Cruiser Discussions 22 05 Dec 2015 10:16 pm
2001 Died while driving compguy Tech & Performance Forum 3 07 Aug 2013 11:43 am
help pt died ;( oldskoolgaz Tech & Performance Forum 3 27 Dec 2011 01:56 pm
2003 PT Cruiser died while driving tlm Tech & Performance Forum 6 24 Sep 2011 01:47 pm
Engine died while driving, Blown ASD fuse & VERY Hot MyCruiserHatesMe Tech & Performance Forum 11 10 Aug 2011 08:50 am
