02 pt cruiser problem starting
  • 1 Post By Busted_PT
Old 03 Feb 2013, 10:24 am
Default 02 pt cruiser problem starting
I have an 02 pt cruiser i had it sitting in the garage for about 4 month i only started the car like 3 time during this time just when i needed to move it out of the way. I recently put it back on the road to let my lil sister drive it and it cranks and starts no problem but dies right 5 sec after and it only does it in the morning before 10AM after that it starts anytime no problem.
I went out there this morning at 8 AM it starts then dies. I went just now 10AM it stayed on no problem and it drives no problem as well. I added some lucas fuel injector cleaner i though maybe it was that but it didnt work. Please help is getting annoying.
Old 03 Feb 2013, 10:42 am
Default Re: 02 pt cruiser problem starting
Dose it start right back up or do you have to wait till 10:00? My first thing to try would be to clean the battery cables. These cars need a strong battery. They have been known to do strange things with low voltage. Sitting is hard on automobile. Battery's don't do well either.
CREWZIN likes this.
Old 03 Feb 2013, 11:54 am
Yes that was the first thing i did was cleaned the battery cables also i have to wait till 10AM
Old 03 Feb 2013, 12:33 pm
Check the other connections on those cables, like the big ground on the inner finder behind air filter box. Did you notice any lights on the dash when it's running? Especially that first start. I wanted to tell you make sure the clock is set to day light savings. But figured you might not be up for that. BTW how old is your battery?
One other thing if it doesn't help, try to boost it with another car and see if it still dose the same thing. But if it's a connection issue it might not make a difference.
Old 03 Feb 2013, 12:47 pm
The battery is not even 7 month old and i checked all the cable to and from the battery and i also checked the alternator and everything is good i was thinking maybe is the iacv valve.
Old 03 Feb 2013, 03:14 pm
I guess anything's possible. Should have a code stored in the computer for this.
Old 03 Feb 2013, 09:19 pm
I dont have the check engine light on
HELP! 2003 PT Cruiser On-going Problem with Starting Issues Nanner Tech & Performance Forum 7 05 Jul 2012 11:59 pm
strange starting problem on 06 pt cruiser piranhafranky Tech & Performance Forum 2 01 Jul 2010 10:26 pm
Dream Cruiser Starting Problem? cruise_carter Tech & Performance Forum 5 03 Apr 2010 06:45 pm
Starting problem Elrodion Tech & Performance Forum 0 18 May 2009 07:49 am
Problem Starting 02 PT Cruiser DavidH General PT Cruiser Discussions 6 20 Feb 2009 06:13 pm
