starter running slowly
Old 06 Feb 2013, 10:21 pm
Default starter running slowly
2006 base model. 145k.
Recently been having slow crank on the starter occasionally, like the battery was low. Sunday is wouldnt start, just cranks over very slowly, chug chug chug. Battery was fairly new, so i got a warranty swap. New battery, same thing. Thought is might be corroded wires/bad grounds, they didnt look too good.
Had new wires made, installed tonite, same thing.
Do the starters in PTs fail like this? I'm used to "works or it dont" starters.
Any other suggestions for diagnosing this? All help appreciated!
thanks all
Dave
Old 06 Feb 2013, 11:37 pm
Default Re: starter running slowly
if the starter has a short in it, it COULD be sucking more amps than it should. not saying that's the case, but i'd have the starter checked.
2016 Kia Soul Plus Black
Old 07 Feb 2013, 08:44 am
Starters can fail in different ways...if you suspect it, you need to have it bench checked. A PITA but if it is bad, you have to pull it anyway.
Old 07 Feb 2013, 09:39 am
Just an outside chance here since you don't have a check engine lite. But a faulty cam sensor can give the slow cranking and no start thing.
Old 07 Feb 2013, 01:12 pm
Ah, now that is interesting! i do get the "check engine" light while trying to start it, but my OBD reader didnt register any error codes, not that i trust it....
Cam sensor would also account for it not even "trying to start", yes?
Old 07 Feb 2013, 03:12 pm
i believe the check engine light should be on when attempting to start. it will go out when running.
Old 07 Feb 2013, 03:15 pm
if the cam sensor is bad, do the key dance.
turn the key to on then off then on 3 times, a code should appear in the odometer window.
i think its the starter 420pt Tech & Performance Forum 21 19 Mar 2013 02:21 am
starter? jmikesch General PT Cruiser Discussions 5 07 Jan 2012 02:15 pm
engine slowly looses power ? gregsguitars Tech & Performance Forum 18 19 Feb 2011 02:43 pm
Bad starter?? jdmickies Tech & Performance Forum 8 06 Sep 2010 11:01 pm
Yep, just another Detail Job! Lot of Photos so may load slowly. Candyman The Detail Shop 5 01 Aug 2009 09:35 pm
