Help with error codes
Old 07 Feb 2013, 05:30 pm
Default Help with error codes
Hi all,
My 2001 PT engine light just came on and I got the following codes. P 0141 & P 1684. I was able to look up what the codes were (Thanks Forum!) but I don't know what they mean.
P 0141 - H02S Heater Performance Bank 1 Sensor 2
P 1684 - Driver 5 Line 4
Anyone know what direction I need to take to make the necessary repair?
Thanks
Scott
Old 07 Feb 2013, 06:44 pm
Default Re: Help with error codes
Your first code is to do with your 02 Oxygen sensor, should be the one at the CAT (Downstream).
The second code is nothing to worry about.
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
Old 08 Feb 2013, 07:37 am
Thank you!
Error Codes bucksfan1976 General Turbo Discussions 0 22 Feb 2011 01:03 pm
2 error codes granty Tech & Performance Forum 7 05 Sep 2009 10:02 pm
no error codes lt4supr Tech & Performance Forum 4 14 Aug 2009 07:34 pm
i got error codes what do they mean feefeethaflee Tech & Performance Forum 3 31 Jul 2009 08:41 pm
