Water leak Under turbo
Like Tree4Likes
Old 08 Feb 2013, 06:14 pm
Default Water leak Under turbo
Hi, I replaced the rubber line beside the air box and cam sensor when I got the car it had a small pin hole. I have been smelling antifreeze for a few days after it warms up. I had the hood open and revved the engine up and looked under the car the water was flowing down at a steady pace under where the turbo is. I looked up top and couldnt find anything. I also just replaced the coolant bottle a few months ago and a new heat shield.
Old 08 Feb 2013, 07:50 pm
VNT's Avatar
VNT VNT is offline
Default Re: Water leak Under turbo
Coolant feed or coolant return lines from the turbo or the lines to the oil cooler.
OurPTGT likes this.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 08 Feb 2013, 09:51 pm
There is no coolant involved with the turbo that I know of.
Old 09 Feb 2013, 10:14 am
reevescajr's Avatar
I agree. The hoses that go to the turbo carry oil, which passes through an oil cooler.
Old 09 Feb 2013, 10:45 am
huh
One of the advantages of these turbos is they're water cooled. That's why it's recommened to let the car idle a few before shutting it down so the coolant can do it's thing
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 09 Feb 2013, 11:19 am
VNT's Avatar
VNT VNT is offline
Guys/gals
Chrysler is the world leader in Turbo Charging, they have sold more Turbo Charged cars than all other makes combined.
They worked with Garret back in the day and to make the turbos last( they had the 5/50 and later 7/70) they water cooled the center section to prevent the coking which plauged, GM and Ford and many of the imports who were too cheap to incorporate such a simple fix.
The 2.4 uses a coolant feed, coolant return, oil feed and oil return lines.
They are the achilles heel, at some point your going to have to change them, because the rubber sections dont last forever, just like upper and lower radiator hoses and heater hoses they will last 10 yrs maybe but at some point they are a time bomb waiting to blow, and it is a total PITA to change them, very tight in the back.
Note also the oil cooler on the turbos has two sections of formed rubber hoses which should be changed.
Lastly these cars at the point in the life cycle where people who have them should start doing some good thought out PM to prevent incidents where say the coolant feed line bursts, and the overheat and cook the engine!
As they say, pay me now or pay me later.
VNT
Old 09 Feb 2013, 12:15 pm
Yes, you're right. Thought the two lines were both oil lines. The one closest to the firewall is at least one of the coolant lines. will get out my spare and look for the return lines. Thanks guys, another good reason for these discussions. I never learn much if everyone always agree. Because the whole story usually doesn't come out if someone isn't trying to show them the true facts. So thanks for not making it a personal battle and providing the information to resolve this .
wwpptc and Ray_Dockrey like this.
Old 09 Feb 2013, 12:52 pm
VNT's Avatar
VNT VNT is offline
Go here to Hot rod article on 2.4
Pic 22 shows close up of back of engine with turbo, will see all 4 lines.
113 0309 Srt 20 Z Photo 22
Busted_PT likes this.
VNT
Old 09 Feb 2013, 01:13 pm
Great pics. Going to have to study that article more later. Maybe you have the specks for shaft play on these. End to end and side to side?Thanks VNT
Old 09 Feb 2013, 02:50 pm
A long, long, long time ago, an op asked how he could be getting water in his oil. He said he and his mechanics had checked every possable entry point and could find nothing wrong.
I replied that i knew of one instance that the turbo oil cooler fixture had failed internally (it is a CAST part and these things can happen with a casting) and allowed coolant to mix with the engine oil. He checked it and sure enough, that was the problem. They replaced the oil cooler and he was a happy camper.
Keep in mind, this is an extremely rare circumstance and those two cases are the only two that I am aware of. NITRO wink/wink (thats an inside joke) we'll see.
In short yes, as was said so well above, it is coolant that flows through the turbo oil cooler fixture.
PLEASE CLICK PICS BELOW
Jerry
Got A Water Leak! bados General PT Cruiser Discussions 16 10 Apr 2017 08:05 am
Exterior Water Leak to F.R. floorboard Lakota General PT Cruiser Discussions 9 02 Dec 2011 09:26 pm
Possibly water pump leak mrwag Tech & Performance Forum 17 23 Oct 2010 03:26 pm
turbo water tube leak PRIMOX General Turbo Discussions 1 19 Jul 2009 04:32 pm
Water leak! PattiV General PT Cruiser Discussions 2 21 Jun 2009 02:24 pm
