07 Cruiser with no spark????
Old 09 Feb 2013, 07:38 pm
Default 07 Cruiser with no spark????
PCM died at 75 mph, snapping the timing belt. At this point we have replaced the PCM, camshaft sensor, crankshaft sensor, coil, timing belt, and spark plugs. At this point it should be running but there is still no spark. Any ideas would be MOST appreciated!!!
Old 09 Feb 2013, 09:18 pm
Exclamation Re: 07 Cruiser with no spark????
Good Evening,
Welcome to the forum
I am assuming you have a 2007 GT 5 speed with 84k miles, that you have been running synthetic oil too and recently got a new gas cap.
Seriously though, more info is needed about the vehicle. There are some good people on here that can help diagnose but you need to provide the basics along with some detail, change the plugs but not the wires???
Old 09 Feb 2013, 11:06 pm
Default Re: 07 Cruiser with no spark????
There is no reason for the pcm or the timing belt to be related. So I'm wondering the pcm was even bad. You might have a bad cam sensor magnet. Assuming that the belt is in time. Also is the coil plugged up?
Old 10 Feb 2013, 02:09 pm
Here is what is theory as to what happened...The PCM went out during the drive for whatever reason, killing the engine. As it died at 75 mph, the timing belt snapped....Right now I am looking for a wiring diagram for the PCM showing voltage, Coil pin out test, and a flowchart for the ignition wiring....
2.4L non turbo '07 with about 150k miles. Always use high mileage synthetic as I drive about 140 mile a day....
Tags
no spark
2001 PT Cruiser won't start. No Spark oscar_the_grouch Tech & Performance Forum 11 09 Sep 2012 10:25 am
07 pt cruiser no spark or injector pulse lilblkshp Tech & Performance Forum 10 14 Jan 2012 09:54 am
01. pt cruiser no spark gjason49 Tech & Performance Forum 1 03 Jul 2011 04:08 pm
Help no spark 2002 pt cruiser zackkbcobra Tech & Performance Forum 14 27 Jun 2011 03:27 pm
2001 PT cruiser, no spark, no fuel..?..?..? ozmr Tech & Performance Forum 9 19 Jun 2010 10:36 pm
