Stuck Fuel injector
Old 09 Feb 2013, 11:36 pm
Default Stuck Fuel injector
I have an injector that is not closing all the way. Runs rough at idle and smells like an open gas can in the car when you first start it up. Other than that the car runs well. Need help determining what injector needs to be replaced.
2001 PT Limited 197,000mi. bone stock for now!
Federal Signal LED warning lights for fire dept. use.
Old 10 Feb 2013, 03:08 am
Default Re: Stuck Fuel injector
The "shade-tree" method would act to finding your answer...After the engine gets warmed up shut it down. Carefully and safely remove the spark plugs one at a time. The spark-plug that is wet with un-burned fuel is your failing injector. Or bad injector harness, broken or faulty wires to the injector,bad spark plug wire and a few other things that could cause a no or partial fire in a particular cylinder causing excess un-burned fuel which would not necessarily be an injector failing?
Old 10 Feb 2013, 09:07 am
Fuel Line Leaks- Look at your PT
^ check that thing
Old 10 Feb 2013, 09:29 am
Try a good infector cleaner first. If you see no improvement. You will need to do what these fine fellows said.
Old 10 Feb 2013, 08:38 pm
Just thinking out loud here but wouldn't something like that set an error code for the cylinder that wasn't firing properly?
2005 Limited, Auto and Turbo Lite
Bone stock
Old 10 Feb 2013, 08:47 pm
In most cases yes but anomalies can happen with no code value.
Old 10 Feb 2013, 09:20 pm
UptownSport's Avatar
pull rail with injector on, unplug electric connectors
Have fire extinguisher
turn key to run, see which dribbles, BPT turn key off
AND
Do as Rob says
Tags
fuel injector, fuel leak, gas smell, rough idle
Fuel Injector Cleaner dwg12 Tech & Performance Forum 10 29 Feb 2012 03:18 pm
#4 Fuel Injector Spray Tip My02RedRide Tech & Performance Forum 0 29 Aug 2011 05:01 pm
Fuel Injector Problem Fruufy Turbo Performance 3 27 Jul 2011 07:21 pm
fuel injector swap for more MPG idea pppt03turbo General Turbo Discussions 0 28 Jun 2008 03:22 pm
Fuel Injector American flyer Tech & Performance Forum 7 14 Jan 2003 12:56 pm
