timing belt loud after replacement? video inside
Old 15 Feb 2013, 03:41 pm
Default timing belt loud after replacement? video inside
well i just replaced the timing belt on my gf's '08 cruiser. Started up just fine, not throwing any codes or anything, but DAMN is this new belt loud. is this normal?
i got the Blue Gates racing belt kit from rockauto and the cam seals, as well as an oem waterpump. seems to drive normal from the short drive i took it on, but the belt is REALLY loud, lol.
Old 15 Feb 2013, 08:16 pm
Default Re: timing belt loud after replacement? video inside
Sounds like the timing may be off.
Or a harmonic balancer is toast.
But im not a timing expert. Someone on here will probably know a lot more than i do :-)
Old 15 Feb 2013, 09:56 pm
thanks for the reply. Sunday I'm gonna start tearing in to it again to try and figure it out. I hope its something stupid I forgot to do and NOT the timing or the harmonic balancer
Old 16 Feb 2013, 03:32 am
I would verify that the serpentine belt is centered in all pulleys. Then check for the proper tension of the belts. Then spray a very light oil [like wd-40, crc 2-26 etc.] on each belt or into the pulley. One belt at a time. Spray both sides of belt if the belt has an outer idler. If no change in noise, remove upper timing cover and check tension. Listen for change with/without cover. Careful. Belts eat fingers!
Old 17 Feb 2013, 05:25 am
It sounds like the belt is rubbing the cover. (I'm not saying it is.)
2008 PT Cruiser Touring 135,000 miles
Old 18 Feb 2013, 10:40 am
The source of noise was the idler!! The brand new one from gates. Need to send them an email and request some kind of compensation now...
Old 18 Feb 2013, 10:46 am
I always turn mine by hand to feel if they are smooth and tight. But that is very unusual to say the least.
Old 18 Feb 2013, 05:59 pm
That blows!! I just purchased one of these kits..Hope I don't have the same problem.My idler feels smooth/fluid when rolled by hand,but who knows at high speed..Does your idler feel rough when you roll it??
Old 22 Feb 2013, 08:49 am
Both the New one and the Old one felt EXACTLY the same, I don't think there was any way to tell the idler was bad. It spun freely in my hand and was really smooth
And we spun it over by hand a good dozen times and it seemed fine
Old 22 Feb 2013, 10:01 am
I and many others have installed this kit without issue. All the pics of mine on my project page. These things happen. To my knowledge, this is the first I heard of this. So the odds are in your favor.
Timing Belt Replacement MarkB Tech & Performance Forum 108 08 Aug 2017 12:59 am
Timing belt replacement snakepitt1 Tech & Performance Forum 10 18 Dec 2016 12:17 am
Timing belt replacement dewey68 Turbo Performance 13 16 May 2012 09:53 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Timing belt replacement??? HELP!!! CRFDAD Tech & Performance Forum 4 07 Jan 2009 08:14 am
