PT Running then completely dead
Old 16 Feb 2013, 06:36 pm
Default PT Running then completely dead
Hi all!
Back again with more issues. We started the car with the remote starter. It cranked right up and ran for about 10 minutes. When we went to step on the brake and start it with the key, everything was completely dead. Then I got out of the car and the dome light came on...I tried to start it, and everything went black again. We had a new battery put in about three weeks ago. Could it be a short or something? I never saw anything like this.
Thanks!
Joanie
Old 16 Feb 2013, 09:10 pm
PTJunkie's Avatar
Default Re: PT Running then completely dead
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 16 Feb 2013, 10:39 pm
It's ether a bad alt or bad connections on the cables. Check all the connections not just at the battery.
Old 17 Feb 2013, 12:32 am
PTJunkie's Avatar
Re-read your post again, and it sounds to be a slipping alternator belt causing it not to turn at the proper speed, hence why is not charging properly.
William____
Old 17 Feb 2013, 03:00 pm
Thank you so much for your response. Okay, so I was looking around because we tried jumping it and all is does is sounds like it's turning over, but won't start. I saw red and white wires, and the red one is disconnected from somewhere. I tried following the white wire, but the whole compartment is just too small. Any idea what that could be, and could those wires possibly be from fog lights my guy tried installing a few years ago?
Thanks again!
Joanie
Old 17 Feb 2013, 04:16 pm
I'm not sure if this picture will work, but this is the wire that I found pulled out of something. We did connect the battery charger right to the battery instead of the positive post, and this red wire could've been the problem, but the only thing is, what caused it not to start in the first place. Hmmm....not sure what this is all about.
http://www.ptcruiserlinks.com/forum/...1&d=1361135614
Old 17 Feb 2013, 04:50 pm
That is not original to the car.
Old 18 Feb 2013, 01:58 am
Not any more. hehe Pull a spark plug to see if it is flooded.
Old 19 Feb 2013, 07:10 pm
Have you considered that possibly there's a problem with the remote start system? Have you had it checked? Are you sure it was actually running for those ten minutes?
-Chris
2006 PT cooling fan keeps running/dead battery pmexaminer Tech & Performance Forum 13 18 Oct 2014 09:07 pm
Completely dead BALLETDAD Tech & Performance Forum 2 26 Mar 2012 12:44 pm
Completely dead battery after parking for 1 month. problem? hushpuppy General PT Cruiser Discussions 16 08 Jul 2010 10:43 pm
...and now for something completely different CREWZIN General PT Cruiser Discussions 14 28 Jun 2009 10:23 pm
