01 PT Cam Problem
Old 17 Feb 2013, 07:15 pm
Default 01 PT Cam Problem
Just did a water pump on my 01 and apparently the mo canic forgot to torque the cam bolts. Needless to say it quit running. Im sure it sheered the shier pins but I dont know if it bent valves,, didnt make any weird noises. Can those pins be replaced and should I even bother, not sure if it bent valves. Very frustrated these friggin things are so dam hard to work on without taking the motor out.
Old 17 Feb 2013, 07:28 pm
Default Re: 01 PT Cam Problem
What pins are you talking about? If you are referring to the key stock pins at the ends of each camshaft they can be replaced. But the general labor cost to do it would be more then you finding a pair of camshafts at an auto wrecker.
Old 17 Feb 2013, 09:31 pm
UptownSport's Avatar
Cam Dowel pin Part Number 6100997
Under $1 from dealer
Old 17 Feb 2013, 11:25 pm
Its not about the in-expense of pin itself!
I believe that if you were to actual change one that is broken at the head of the camshaft you would understand my posting to simply get another set of OEM camshafts. If they were billets or having a custom grind machined I would have recommended having a engine machine do the task.
You might try removing one broken at the base and understand what I am talking about. It would take me about 1/2+ to do two cmashfts! Thats about $50-75+ in most compentant shops.
Old 18 Feb 2013, 12:40 am
why not have the mechanic fix his mistake? i know i would. you pay for a service and if done incorrectly, you take it back.
2016 Kia Soul Plus Black
Old 18 Feb 2013, 08:24 am
I agree,, yes it did snap off the shear pin. What are the chances it bent valves? Do they stick down far enough in the cylinder to do that?
Old 19 Feb 2013, 05:07 am
sometimes
Old 19 Feb 2013, 01:38 pm
Which cam? Orange with Green stripe?
I prolly have one-
Old 19 Feb 2013, 01:46 pm
I prolly have one-
I found one here and will stick it in tonight Lets hope there are no bent valves
Old 19 Feb 2013, 11:35 pm
I'm sure you'll be fine!
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
Cat problem?? ggd PT Cruiser Convertible Forum 0 30 May 2005 09:53 pm
is anyone else having this problem? blustar714 PT Cruiser Convertible Forum 0 05 May 2005 11:32 pm
Problem? deederz Tech & Performance Forum 3 04 May 2005 10:19 am
