Dyno Shop?
Old 18 Feb 2013, 02:00 pm
Default Dyno Shop?
Does any of my Southern California Cruiser friends know of a good dyno shop where I can get my cruiser tuned?
Old 18 Feb 2013, 02:23 pm
Default Re: Dyno Shop?
Are you referring to and EFI/ECU calibration or just a standard engine 'tune up"?
If the first what ECU tool are you using? If you have not gotten one yet then using a Chassis Dyno is not the best money spent until you do have one? And if you did you should be data logging as much as you can before getting a run.
A baseline Dyno run is a very good idea so you can see improvement with other engine upgrades in the future to be able to see what actually worked and approximately by how much?
If you do this have the shop give you there Delta information so you can duplicate the set up. many do not and get questionable results with future runs.
As far as your first question goes I know a few shops but none are "PT" savoy they are just Performance shops. You need to make your own personal friends with the shop you choose if you plan on several returning runs so they can get to know you and your PT.
Old 19 Feb 2013, 12:50 pm
I recently put in a k&n cold air intake on my base cruiser and it has killed my gas mileage, I was wondering if this could be fixed by tweaking the ecu, i would prefer someone who has knowledge of doing these other than tackling it myself.
Old 19 Feb 2013, 12:53 pm
Curious...... what are all your PT mods?
Old 20 Feb 2013, 06:04 pm
the only serious mods that would change the mileage are the cold air intake, a bigger exhaust (4 1/2 in) and bigger wheels (17s), before adding these I wouldnt get great mileage (around 18city 24highway) but since these its been down to about 14city and 20highway, so I was just curious if tweaking the ecu would make a difference or not. I was also looking at a jet performance chip, but was unsure if they work or not.
Old 02 Dec 2013, 08:58 pm
Don't know if you got it figured out yet, but if not, my name is Josh and I own JEP Autoworks and we have a in house Chassis Dynometer - And we're in Hemet
Call me and I might be able to help you out - (951) 487-3938
- Josh
Old 05 Dec 2013, 11:56 pm
- Josh
Did you actually mean to say that you installed a 4 1/2 inch exhaust?
Josh, what a co-inky-dink.
Jerry
Old 06 Dec 2013, 01:34 am
Maybe he meant his tip was 4.5 inches not his full exhaust
No pun intended
Old 06 Dec 2013, 09:09 am
maybe your speedometer is wrong because of the larger wheels and you still get the same mileage.
looks like CA uses the same mileage killing winter blend gas they push in illinois. that costs you "a little" mpg as well
you were asking about a CA inspection a few months ago weren't you? what intake did you have before that? did that one affect the mileage? it should help, not hurt. -unless you're flooring it more. what did you do with the PCV hose? are the new rims wide and heavy?
IMO you're nuts if you want to dyno a stock NA automatic PT
No pun intended
aaaahahaahahhaha
Dyno dodge-boy General Turbo Discussions 61 31 Aug 2004 06:12 pm
dyno run 08/18/04 Nudle Turbo Performance 3 19 Aug 2004 09:36 am
Finally got on the Dyno...@@Dyno Scans@@ TripleJackInGA Turbo Performance 30 01 Jul 2004 12:14 pm
where's a dyno shop? Punch Canada PT Forum 7 07 Oct 2003 09:50 pm
