Waterpump............01 PT
Old 18 Feb 2013, 04:20 pm
Default Waterpump............01 PT
The price to have a water pump replaced is outrageous.... the water pump is only 50.00 the labor is 659.00...... dang......... That is ridiculous!!!!!!
Old 18 Feb 2013, 04:25 pm
Default Re: Waterpump............01 PT
Does anyone know where I can get my Water pump changed any cheaper in Mobile Alabama?
Old 18 Feb 2013, 04:26 pm
You haven't been reading the forums. The same amount of labor (5 to 7 hours) is needed for the water pump as to do the timing belt. We always tell everyone to do them both at the same time.
You didn't say what mileage you have. ANYWHERE near 100,000 miles, do the timing belt, belt tensioner and water pump at the same time.
That's actually pretty cheap to get in there to do the job. Most dealers want $1000-$1200 for the things I've mentioned.
Old 18 Feb 2013, 04:30 pm
The PT is a 01. Had the timing belt replaced at 102,000. And the water pump has been replaced before. It has 166,000 on it now. Bought the PT for 1000 and put about 600.00 in it so far. Now this.....
Old 18 Feb 2013, 04:34 pm
Always a good idea to go for an expensive/well made part when it takes that much to get to it. Is the pump leaking to show that the internal workings are bad?
Old 19 Feb 2013, 09:36 am
Yes the pump is leaking so it is internal. I'm taking it in on Thursday. I agree with you.. It will be cheaper than a new car....... But I like the PT and my son just put a Stereo in. We have plans on putting amp and sub woofer down the road..... I do appreciate the help.
Old 19 Feb 2013, 09:49 am
OK. Personally, you have about 60K on the timing belt. Supposed to be changed around 100K (as you know) so, if you plan on keeping the car, it's just as easy to change the timing belt again, in fact the belt has to come off to get to the pump so I would have that and the belt tensioner changed while doing the pump.
Old 19 Feb 2013, 11:18 am
AND, while they're in there, throw in a new thermostat.
Old 19 Feb 2013, 10:58 pm
compdr59's Avatar
How do you know its the water pump? There are other items that leak and drip in the same area.
Busted_PT likes this.
Original Owner 135k
Old 19 Feb 2013, 11:12 pm
This happen to NitroPT. For a few hours. And he is a technician.
Leaky waterpump only 20k... wheelgarage Tech & Performance Forum 22 19 Dec 2011 05:03 pm
2004 2.2 CRD Waterpump replacement elwell Tech & Performance Forum 2 06 Oct 2010 09:27 am
Waterpump replaced, now problems. ptguy Tech & Performance Forum 4 07 Sep 2007 05:12 pm
