Light Knocking on Cold Starts Only
Old 20 Feb 2013, 07:45 am
falconut's Avatar
Default Light Knocking on Cold Starts Only
I've been hearing a light knocking sound, but only on cold starts. After a minute or two, it's gone and I don't hear it again. This is from the passenger compartment. I've tried to listen to the engine with the hood open, but don't hear it. I thought I heard it once when I had the passenger wheel off and was it there doing my motor mounts. Any ideas?
My car is a 2007 Base Model N/A 2.4L with about 87,000 miles.
Old 20 Feb 2013, 02:35 pm
Default Re: Light Knocking on Cold Starts Only
When was the last time you changed oil? What weight are you using? might want to try a lighter weight if your at 10w30/40.
Old 20 Feb 2013, 03:40 pm
falconut's Avatar
It's been there for a few changes. I change my oil every 3,000 miles (about every 2-1/2 months). Last change was 1,000 miles ago (about 3 weeks) and I used Valvoline High Mileage 5W-30. I was told this was a semi-synthetic (70/30 mix).
The last two changes before that, I used Castrol GTX Syn-Blend 5W-30. I've been using semi-synthetic for the last couple years. I tried a full synthetic (Penzoil Platinum), but it was making ticking on startup, so I switched back to the semi.
Old 20 Feb 2013, 04:01 pm
PTJunkie's Avatar
Try adding some Marvel's Mistery Oil in the crankcase.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 20 Feb 2013, 04:23 pm
falconut's Avatar
After reading on their site, it says to replace 1 quart out of the 5 quarts with the Marvels. I'd have to wait until I'm ready for an oil change, since it would overfill it now.
I'm guessing that you've used it in your crankcase before.
Old 20 Feb 2013, 05:10 pm
PTJunkie's Avatar
I sure have! I had an '87 Mazda B2200 years back, it run great but had a nasty ticking sound.. it sounded like a sewing machine at start-up lol . I used to put a couple of ounces every oil change and that would take the noise away. It really worked, and no issues ever.
I remember putting some in the gas tank too, not much tho..a cap or so.
William____
Old 20 Feb 2013, 06:25 pm
falconut's Avatar
So, about 2 - 4 oz. in the oil works? Maybe I'll have to try it.
Old 20 Feb 2013, 06:36 pm
PTJunkie's Avatar
Yes Sir..it will do no harm.
William____
Old 20 Feb 2013, 07:30 pm
falconut's Avatar
Picked up a 32oz bottle of MMO (they were out of the 16oz.) and added a capfull to the oil and a capfull to the fuel. We'll see if this helps.
Old 20 Feb 2013, 08:11 pm
PTJunkie's Avatar
OK, keep us posted..
William____
Help...oil light, cold heat ashleyoh General PT Cruiser Discussions 11 02 Feb 2015 01:03 am
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
Engine warning light goes on, and sometimes the car starts chugging Nova General PT Cruiser Discussions 12 01 Jul 2012 05:07 pm
Timing Belt Was Just Replaced - Oil Warning Light at Cold Start Up ? PURPLE_GT General Turbo Discussions 10 05 Jan 2012 06:58 pm
2004 PT cruiser Engine light on and Knocking moonfairy16 Tech & Performance Forum 13 18 Dec 2008 03:32 pm
