2005 PT 5 Speed Won't go in reverse
Like Tree2Likes
  • 1 Post By NitroPT
  • 1 Post By UptownSport
Old 20 Feb 2013, 08:31 am
Default 2005 PT 5 Speed Won't go in reverse
It will gift through all gears but when trying to put it in reverse it won't even act like the gear is there. The car does roll backwards but won't go in to the reverse gear. It will go in to other gears but sometimes will get stuck in a gear and I have to pump the clutch to get it out of gear.
Thoughts?
Thanks for the help!
Old 20 Feb 2013, 09:25 am
Teska's Avatar
Default Re: 2005 PT 5 Speed Won't go in reverse
Worn clutch ? I think the reverse will always be the first gear that jamms.
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 20 Feb 2013, 10:17 am
does it go in if the car is not running? like if you put it in reverse, press the clutch, and then start it?
Old 20 Feb 2013, 10:51 am
Cable bushings are a known problem also.
Old 20 Feb 2013, 11:25 am
As per his description I would have to agree with busted_pt. ^^
The reverse is on its own shaft and has its own synchro. So the OP does not describe any grinding and the forward gear are working so I would look at the cables.
Busted_PT likes this.
Old 20 Feb 2013, 05:34 pm
UptownSport's Avatar
Follow this link to see your problem, click booger bushings.
Booger Racing
Neons (same as PT here) have had this problem since 1993.
I do have a set of non-turbo cables on e-bay, but highly doubt you need anything more than booger bushings.
PT Cruiser Manual Transaxle Gearshift Control Cable 4668268AC Non Turbo | eBay
Teska and Rob are correct, a dragging clutch will make R difficult to impossible to engage, as Nitro says, R is on it's own shaft and unlike the other gears isn't constant mesh!
rcktpwrd likes this.
Locating Radiator Fan relays High Speed and Low Speed CashReject Tech & Performance Forum 14 06 May 2017 12:12 am
FS OEM reverse lights ....both lenses 2001-2005 tpsfoto Classifieds: For Sale/Trade 4 16 Feb 2015 09:35 am
2005 4 Speed Auto - Won't Go Into Any Gear jmbrads1 Tech & Performance Forum 5 12 Dec 2012 07:39 am
Lost Reverse Lights & Reverse Shift Bell wunderbluegt General Turbo Discussions 1 06 Jul 2004 10:12 pm
Is the 4 Speed A/S realy a six speed? Ian-PT-GT General Turbo Discussions 11 16 Apr 2004 10:19 pm
