06 Cruiser overheating
Old 21 Feb 2013, 03:38 pm
Default 06 Cruiser overheating
My 06 PT cruiser is overheating. I changed out the radiator cap & thermostat & the coolant level was fine, no loss of coolant. This took me an hour and a half so the engine had cooled significantly, then when I started the car the Temperature gauge was immediately all the way up to HOT & the car had not even run for 1 minute. I took off the radiator cap & looked to see if the coolant was circulating in case the water pump may have failed, but it seems to be circulating the coolant. My only other guess is the temperature sensor may be bad. When a mechanic changed my timing belt he had forgotten to plug in the temperature sensor wire, so the car always showed the temp as flat "Cold" once I plugged it in it showed it as right in the middle where it usually is. Could this wire have shorted out & caused the engine to "think" it was over heating?
Old 21 Feb 2013, 03:43 pm
Default Re: 06 Cruiser overheating
The biggest cause of overheating for the PT is a failed radiator fan followed closely by a clogged radiator (usually on the older models). The first thing for you to do is check to see if both speeds of your fan are running. If you don't do your own work, ask someone with a scanner to run the fan through the two cycles to make sure it's good.
Tags
overheating
Cruiser overheating rdpar General PT Cruiser Discussions 2 05 Jul 2012 09:09 pm
My Pt Cruiser is overheating JonS Tech & Performance Forum 4 18 Jun 2012 05:58 am
02 PT Cruiser Overheating jpcruz Tech & Performance Forum 6 28 May 2012 10:27 pm
01 Cruiser overheating... DeviantPT General PT Cruiser Discussions 15 24 Aug 2011 02:24 pm
Another OverHeating Cruiser....... FloridaCrusier29 General PT Cruiser Discussions 8 26 Jul 2007 09:25 pm
