Wher eis the Trans Control Module located
Old 23 Feb 2013, 11:44 am
Default Wher eis the Trans Control Module located
2002 PT and the trans no longer shifts out of first. Has a code that says TCM is the issue. Where is the TCM located? Is it in the trans, on the trans, or in a different spot away from the trans? What does it look like, can someone post a picture? My wifes car has high mileage but is in pretty good shape and was running fine before this trans no shift problem. I am not ready to get rid of it as we like driving and playing in this car. So thanks for any info and pictures you can provide.
Jerry
Old 23 Feb 2013, 12:12 pm
Default Re: Wher eis the Trans Control Module located
To my knowledge its the module were the wiring harness plunges into the transmission. On the front side of the trans. might need to pull the battery to see.
Old 23 Feb 2013, 12:47 pm
According to Haynes, one way to get to it is through the front left wheel well. Precautions are that you ground yourself and the TCM before handling it and that you don't interchange TCM from different year vehicles.
Old 25 Feb 2013, 01:07 pm
Thanks for the pictures and info. Starting point to get mine back on the road.
Transmission Control Module BoneDaddyCruiser0808 Tech & Performance Forum 4 30 Jun 2013 05:22 pm
Where is the ignition (control) module? bjagd02 General PT Cruiser Discussions 5 26 Feb 2011 05:21 pm
Front Control Module? rose Tech & Performance Forum 10 24 Jan 2011 07:08 pm
transmission control module gatorlake Tech & Performance Forum 1 22 May 2009 10:46 am
Transmission Control Module j1stahl Tech & Performance Forum 5 30 Apr 2004 08:57 pm
