New Watts Link and Rods
Old 23 Feb 2013, 02:50 pm
My02RedRide's Avatar
Default New Watts Link and Rods
Lowered Tein frt and rr springs the rear axle was shifted to the right 7mm (about 1/4"). Nothing major but it just bugged me. Just installed a new watts link and Moog link rods. Parts on were original but not worn or noisy, just doing preventative maintenance. The Moog right side short arm has a lock nut on the ball joint and is adjustable. Length was same as original but what I did was loosen the lock nut and wound the ball joint IN 3 full turns. Installed the parts and torqued the bushing ends to the body with the vehicle resting on the jack stands per the manual. Took a drive to settle everything in and re-measured and now side to side is within 2mm. I would say close enough.
Watts-Link or Bellcrank Replacement twress Wheels, Tires, Suspension 92 26 Jul 2017 10:10 am
watts link woes... mdskinner731 General PT Cruiser Discussions 1 23 Feb 2013 05:14 pm
watts link terrylittlejohn Tech & Performance Forum 12 25 Jan 2011 07:00 pm
Watts link bolt ado63 Tech & Performance Forum 2 11 Oct 2010 04:36 pm
watts link part numbers visual1 General PT Cruiser Discussions 4 21 Aug 2009 02:12 pm
