Transmission seal leak
Old 24 Feb 2013, 07:53 am
Default Transmission seal leak
Have a transmission leak, believe it's from the seal on the driver side, drive axle.
Wondering this anyone has taken on this repair.
Re: 2001 PT Cruierser 97,000 miles.
Old 17 Mar 2013, 12:28 pm
Default Re: Transmission seal leak
You might want to check your solenoid pack, as these are known for leaking. It may or may not be the issue with yours, but it solved the problem on my end. Good luck!
Old 17 Mar 2013, 02:12 pm
Did this job on a minivan years ago...same transaxle. First make sure that the leak is actually coming from the drive axle before you tear everything apart. My advice is to get a Chiltons or Haynes repair manual...it walks you through this job. Took me all day (did both sides)...a lot of work to replace a few $ part but saved me hundreds compared to what the dealer wanted to do the job. Good luck.
Front crank seal oil leak Pt4Me General PT Cruiser Discussions 10 25 Nov 2012 03:27 am
Rear main seal oil leak 2005 turbo convertible. Deen General Turbo Discussions 7 09 Jun 2012 06:32 pm
REAR MAIN SEAL OIL LEAK johngubbio General PT Cruiser Discussions 5 18 Feb 2012 08:29 pm
Door seal leak mgreenb561 General Turbo Discussions 1 27 Jan 2012 04:14 pm
Transmission leak!!! Milowe General PT Cruiser Discussions 1 17 Jun 2008 03:44 pm
