Rough idle, check engine light
Old 24 Feb 2013, 12:54 pm
Exclamation Rough idle, check engine light
I went to start my 05 base model cruiser up today and got a really rough idle. Thought maybe if I let it run it'll smooth itself out, it does is from time to time. When I went to pull outta the drive way, the check engine lit came on. Tried the key dance, but nothing showed..so I may not be doing it right.
Eh spark plugs and wires are fairly new....me and old man have cleaned the IAC out once before, but its been awhile. Every now and again the oil send pressure light comes on, but after turning the car off it turns itself off...
So any thoughts?
Old 24 Feb 2013, 12:55 pm
Default Re: Rough idle, check engine light
Oh yeah, the car has 85k on it, and gets regular oil changes with 5w30 and all fluids are checked every time it's serviced.
Old 24 Feb 2013, 01:03 pm
Try the key dance again. It helps us help you.
How to retrieve fault codes.
Old 24 Feb 2013, 01:16 pm
Error code P0301.
Old 24 Feb 2013, 01:20 pm
That's a miss from cylinder #1. The cylinder to the left as your looking at the engine. Could be a bad spark plug wire or spark plug or a small leak from the seam of the upper manifold or where the manifold comes together with the lower part.
Old 24 Feb 2013, 01:24 pm
K. Will try a new plug to start with, and see how it goes from there. Will post later to confirm or deny problem solved.
Old 24 Feb 2013, 01:44 pm
If your going to the trouble of changing a plug, take the old #1 plug AND #1 wire and move it to another position. Then when it's all back together, try the key dance again. If the number moves to P030# (# indicates where you moved the plug and wire to) then you know the problem was the wire or plug. If the key dance says P0301 again, you might have an internal problem or like I said first, a small vacuum leak around cylinder #1.
Old 24 Feb 2013, 03:33 pm
We had already left when you posted last crewzin.
We changed the plug and cleared the code. We took it for a short test drive and nothing came up as far as a check engine light or other warning. I think we took care of it. Thanks for the help though!!!!
Old 24 Feb 2013, 03:42 pm
No problem. Good luck and hope that's the end of it.
Old 24 Feb 2013, 04:14 pm
Just took it for another , longer, run. It's smooth, and still no warning lights. Think we got it.
The plug was pretty badly worn in the time since it was installed, so it was most likely the culprit.
I appreciate all the info u and other posters have given me on all the ins ands of this car. Feeling like I really know what I'm doing when it comes to figuring out problems that arise with this quirky little car.
-Very- Rough Idle and engine dies + hot air purplecruiser Tech & Performance Forum 6 27 Feb 2015 11:09 am
2007 pt cruiser rough idle with check engine light firstblackbelt2010 Tech & Performance Forum 1 01 Sep 2012 07:34 am
Very Rough Idle, engine dies sometimes jonlouisville77 Tech & Performance Forum 13 03 May 2012 12:37 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Rough idle/engine miss while driving smithtls Tech & Performance Forum 5 10 Oct 2002 02:02 pm
