Help! Bent valve?
Old 26 Feb 2013, 10:32 am
Red face Help! Bent valve?
Let me preface this by saying that i am an idiot. While changing my water pump, oil, plugs, etc., i managed to suck the blue shop towels that i had stuffed in the intake with the plenum off. I forgot about them when i put it back together somehow they had already been sucked in when I put the plenum on, and I didn't notice it. there was a small pimg while trying to start it that first time, and of course it jumped time. I'm in the process of tearing it back down, and was wondering what kind of damage these heads are prone to, and if nothing's bent, what should i look for in this head?
'04 PT no turbo, manual transmission
Old 26 Feb 2013, 11:05 am
Default Re: Help! Bent valve?
Valves will only bend when they collide with one another. Will not make contact with piston. pull the intake upper and lower and see if you can retrieve the shop towels. Put them back together like a puzzle to make sure you get it all out.maybe you only have one or two open a little. But maybe not bent.
Old 26 Feb 2013, 11:13 am
Well, I guess it's possible the rags wadded up in the lower intake half and didn't gi thru and screw up intake valves - take off lower intake and see ....
Old 26 Feb 2013, 11:28 am
Found three of the rags wadded up at the intae runners, the other, in #3, i only found a small piece of wrapped around the valve, as iget the timing set back off, i'll spin that cam and see what i find, but theres an entire shop towel missing in cylinder #3. 've got a head set just in case, but damn i don't wanna pull it that far down.
Old 26 Feb 2013, 11:29 am
cruserdad1976's Avatar
hard to imagion a rag making it inot the cylender??
Old 26 Feb 2013, 11:32 am
that's what i thought, but the damn thing is missing, i'll get back out there in an hour or two, and let you know what i find, any thoughts on the lifters? anyone? i did hear a ping sound a couple times when i tried to start it that time. It was a blue paper shop towel by the way.
Old 26 Feb 2013, 11:39 am
well a paper shop towell is diffrent than a red rag btu still i dont see how it could get in there
you are probaly ok on the valvues and lifters they are pretty tough
the towell may be pluging up something and not allowing any air in but i just cant see it going into a cylender
Old 26 Feb 2013, 11:51 am
that's my feeling, but the damn thing wouldn't start, right after it happened, i thought the same thing, that a towel couldn't make it all the way down there, but when i put it back together, (i never did find the rest of the towel in #3) and tried to start it, it jumped immediatly again, i know my marks were right, and that stupid tensioner assembly was lined up as perfectly as i could tell, i have a new belt in case i stretched that one, and i'm about to pull the exhaust manifold of to look in there, i can't imagine a paper towel doing all this, but when i pulled it apart again, (third time, now) i'm finding bits of the towel on the valves again, in number three, Ive shined a flashlight down the plug hole, looking in through the valves, and can't see anything even with the piston all the way up, maybe it got caught up in the exhaust valve? i'll keep you posted.
Old 26 Feb 2013, 12:10 pm
wouldnt it have to go through the injector??? to get inot the cylender???
Old 26 Feb 2013, 12:27 pm
this is what i found when i pulled the intake the first time, #2 had the rag right there as well, i had to rotate the intake cam to get the towel out of all of them, but #3 was mysteriously empty except for a small scrap about half the size of a dollar bill, we searched inside the cylinder with a flashlight and a pick and didn't find anything, and figured whatever might be left inside there would probably burn up and go out the exhaust as ash. It didn't i guess, and it jumped time again. I dunno, I have the engine on a stand at the moment, with the head still on, i just don't wanna pull it if i don't have to. the runner in the intake is a smooth bore, with the injector actually mounted slghtly out of the bore pointed directly at the valves, cruiserdad1976, so the rags just slid right by the injectors then became soaked in gasoline.
Bent valves? 1971GTX Tech & Performance Forum 8 23 Mar 2012 04:34 pm
Front End Alignment/Bent Tie Rod Emilia General PT Cruiser Discussions 5 25 Mar 2011 08:30 pm
Slightly Bent Aluminum Wheel Matt42 Wheels, Tires, Suspension 1 02 Nov 2009 09:23 am
custom bent dual exhaust in so cal josheypt Classifieds: For Sale/Trade 0 12 May 2005 02:07 am
Bent Wheels robinjoe Wheels, Tires, Suspension 21 28 Mar 2005 01:18 pm
