Automatic Transmission Pan Bolts....
Like Tree2Likes
Old 28 Feb 2013, 08:26 am
a_bartle's Avatar
Default Automatic Transmission Pan Bolts....
I removed the transmission pan last night for a filter/fluid change. The car is a 2001 with only 27,000 miles on it. Pretty sure this is the first time the pan has been removed. I had trouble getting a of the few bolts out, one I "thought" was going to break (lucky it didn't, but the head is a little messed up). As difficult as these bolts were to remove, it almost makes me think I should be putting anti-seize on them rather than loc-tite. Once they are torqued down to specifications, would I really have to worry about them loosening up (if I were to use anti-seize)?
Also, what are your thoughts with replacing the bolts with stainless steel ones? Would they be stronger and less likely to break (and not rust so much)?
Old 28 Feb 2013, 09:21 am
Default Re: Automatic Transmission Pan Bolts....
I would "chase" the threads before replacing the bolts or run a tap in to clean up the threads.
Stainless steel fasteners are not all SS they have iron in them . They WILL rust! the only way to get true SS fasteners is medical grade certified fasteners.($$$) And then you must be very careful to read the hardness value.
The use of anti-seize on a fastener if you torque to yield correctly should not cause them to loosen. I would recommend to chase the thread and use a blue thread loc-tight instead of anti-seize.
Busted_PT likes this.
Old 28 Feb 2013, 10:13 am
Whatever you do, don't use LOCTITE RED. Put that darn stuff on my "8" ball shifter and now it'll NEVER come off. Hopefully I'll never have to.
Old 28 Feb 2013, 10:48 am
CREWZIN
This will not work for you but others in most circumstances will work?
For you CREWZIN
Or
Old 28 Feb 2013, 10:56 am
Yea, I can see me taking a blow torch to my "8" ball now. Think I'll just keep it on till the time comes that I ever need to take the center console out.
Old 28 Feb 2013, 10:57 am
Originally Posted by NitroPT View Post
CREWZIN
Or
This is for CREWZIN Nitro, SMART A$$!
Old 28 Feb 2013, 11:06 am
i agree on chasing the threads. but DON"T use a tap. taps are for making new threads, not chasing old ones. it's VERY easy to ruin things using a tap in hard to reach places. plus the tips are tapered, so unless you're using a bottom tap, it won't do a good job anyways.
get a bolt of the same size from the hardware store and cut or file a notch or two in it. i have one for every sized bolt my mustang takes on hand just for this purpose. cheaper, easier to get the correct size, idiot proof, and works great. you can use a dremel, angle grinder, hacksaw, or hand file to do it. like this:
-not trying to bust your balls Nitro
Carl48 likes this.
Old 28 Feb 2013, 11:51 am
cruserdad1976's Avatar
just curious what does that do????
Old 28 Feb 2013, 12:36 pm
the edge of the slit scrapes the threads clean and the notch fills up with all the debris. it will even fix slightly messed up threads by lining them back up. works great for getting greasy sludge, rust, RTV, dirt and other muck out.
here's a before and after of one after using it on greasy threads. it's so full of crud it actually looks like they never cut it.
^stole this pic from google^
Old 28 Feb 2013, 02:18 pm
interesting. Never seen that before. <thumbs up>
Thanks
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Automatic Transmission 01limited94 Tech & Performance Forum 5 01 Feb 2013 10:09 pm
Automatic transmission leaks Printman General PT Cruiser Discussions 2 10 Nov 2012 02:54 pm
Automatic Transmission ptcruisersam General PT Cruiser Discussions 7 08 Feb 2012 06:43 am
Automatic transmission oil change bhunt41 Tech & Performance Forum 2 02 Dec 2011 11:10 am
Transmission Bolts Leroy Tech & Performance Forum 7 12 Nov 2010 06:24 pm
