Oil light on at low idle
Old 28 Feb 2013, 11:07 am
Smile Oil light on at low idle
Hi!
I have seen similar threads about this problem, but I haven't seen one get a complete answer.
My 2001 n/a cruiser with 170k on her has the oil light come on at low idle. Initially after internet research, I thought it was the sensor. I changed it, and while off checked the pressure which was fine at idle. The very next day, the light came on again, around 800 RPM. Each time I stopped at a light on the way home, it would bing. I had to quickly shift to neutral and rev to keep it off. It was not a fun drive home.
I am concerned it is the oil pump or oil pickup. I am going to take her to have an oil change with higher weight today (10W 30) to see if that helps but I am worried that will make the pump work harder or clog the pickup more.
Is there a way to keep the engine idling at 1000 and above? Tweaking the carburetor comes to mind, but alas, there isn't one.
Thanks!
Old 28 Feb 2013, 11:17 am
Default Re: Oil light on at low idle
Answered on your other post. Please don't post the same question twice.
Tags
low idle, oil light, oil pressure, oil sensor, tweaks
Seriously need HELP!!! Oil light comes on when idle!! jab2810 Tech & Performance Forum 13 22 Jun 2018 05:30 pm
Rough idle, check engine light wheeluh_boy Tech & Performance Forum 11 26 Feb 2013 03:59 pm
2007 pt cruiser rough idle with check engine light firstblackbelt2010 Tech & Performance Forum 1 01 Sep 2012 07:34 am
Blinking Oil Light at idle bandaide Tech & Performance Forum 6 17 Apr 2012 09:31 pm
'01 Oil Light coming on at idle. charbee General PT Cruiser Discussions 3 05 Dec 2009 10:34 pm
