Axel Seal Leak?
Old 28 Feb 2013, 03:27 pm
Default Axel Seal Leak?
I have been trying to fix an oil leak on my 2003 GT 5 speed manual. I have changed the valve cover gasket since there appeared to be a slight leak at the right front side of the engine. I also replaced the oil filter adapter gasket. After this there did not appear to be a leak from the engine at idle. I drove the car about 120 miles and there was quite a bit of oil dripping out of the bottom right side. It seems to me that this leak is coming from the right drive axle/transmission seal since there appears to not be a leak at idle. The axles were replaced about 5000 miles ago(before I bought the car). Anyone have experience with this? I do not have my Chilton manual with me. Do I need it or special tools to replace the seal? Appreciate any help. I really want to get this taken care of.
Old 28 Feb 2013, 03:30 pm
Default Re: Axel Seal Leak?
it should pop out fairly easily. make sure you get the right one pt gt 5-speed manual trans axle seals
Tags
axle, leak, oil, seal, transmission
Transmission seal leak rcalzadilla Tech & Performance Forum 2 17 Mar 2013 02:12 pm
Front crank seal oil leak Pt4Me General PT Cruiser Discussions 10 25 Nov 2012 03:27 am
Rear main seal oil leak 2005 turbo convertible. Deen General Turbo Discussions 7 09 Jun 2012 06:32 pm
REAR MAIN SEAL OIL LEAK johngubbio General PT Cruiser Discussions 5 18 Feb 2012 08:29 pm
Door seal leak mgreenb561 General Turbo Discussions 1 27 Jan 2012 04:14 pm
