replacement power steering pump
Old 02 Mar 2013, 10:22 am
Default replacement power steering pump
I'm working up for doing timing belt and water pump and belts this spring. It's an 05 turbo approaching 90,000 miles. I noticed a shaft seal leak on power steering pump. This will be the fourth power steering pump, 2nd was a NAPA that lasted less than 5 miles. 3rd was the free replacement NAPA that has been on less than two years. Has anybody had good luck with a brand of replacement pump?
Old 05 Mar 2013, 06:42 am
Default Re: replacement power steering pump
I did research on other message boards as this is basically a generic question. The unscientific preference between the big three choices seems to be ACDelco first, then Cardone, then ATSCO. My Ford parts supplier says his motorcraft stuff comes in from ACDelco, so that's what I'm going to try.
power steering pump replacement dannyces Tech & Performance Forum 8 01 Feb 2017 03:51 pm
Power steering pump TexasPTCruisin PT Cruiser News and Rumors 4 23 Nov 2012 04:04 pm
Power Steering Pump Out! lovemyturbo Tech & Performance Forum 4 12 Feb 2011 06:10 am
Power Steering Pump Replacement meder2487 Tech & Performance Forum 1 04 Feb 2011 10:43 pm
Power Steering Pump Chrysler1924 Tech & Performance Forum 7 06 Aug 2010 02:51 pm
