Power steering
  • 1 Post By UwharriePT
Old 03 Mar 2013, 03:55 pm
UwharriePT's Avatar
Default Power steering
I have a bad power steering leak. I found the leak? It is coming from what looks like some type of sensor on the back side of the rack and pinion unit. What is this sensor. I don't have a lift and can't get to it from the ground so off to the neighborhood shop it goes since the power steering pump also needs replacing as it is pretty noisy.
Any chance it is just a fitting?
Thanks
Old 03 Mar 2013, 04:41 pm
Default Re: Power steering
There's a Power Steering Pressure Switch that a lot of owners had to change, mostly because of a fault light from the computer.
Old 03 Mar 2013, 06:40 pm
UwharriePT's Avatar
Yep that's it. Can reach it on the ramps so I guess I have to take it to the local garage.
Old 04 Mar 2013, 10:14 am
UwharriePT's Avatar
All fixed. $110. The sensor was also causing the noise, so pump was fine thank goodness.
Busted_PT likes this.
Old 04 Mar 2013, 03:25 pm
Thanks for the update. We like to know how things turn out.
Old 04 Mar 2013, 04:35 pm
Your welcome.
Old 04 Mar 2013, 06:29 pm
UwharriePT's Avatar
We greatly appreciate the info. I have a great garage, they could have easily said I needed the pump as well, since I thought the noise meant the pump was shot as well. But they told me the noise was the sensor sucking in air.
New sensor= no leak and no noise!
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Power steering TexasPTCruisin PT Cruiser News and Rumors 4 29 Jan 2013 09:43 am
Power Steering DonGee Tech & Performance Forum 3 09 Dec 2011 07:34 am
Power Steering ? reklaweelmada Tech & Performance Forum 5 24 Dec 2009 08:08 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
