03 PT GT 5spd: Wont Start
Old 04 Mar 2013, 11:07 pm
Send a message via AIM to fortknox82 Send a message via Yahoo to fortknox82 Send a message via Skype™ to fortknox82
Default 03 PT GT 5spd: Wont Start
So I have an issue here im trying to track down. I think its the ECM but wanted to get some other opinions.
Timing belt is not broken, car cranks but wont start, has good fuel pressure, but spark is the issue.
When cranking it is intermittent or weak.
You would think cam or crank sensor but Im not going that direction because I have no trouble codes stored at all except for that stupid SKIM key one.
Its kind of wierd how it all happened at once too. Drove to work and when I pulled into my spot noticed a lot of smoke coming from under the hood. Couldnt track it down and decided to let it cool off and check it later. Came back out to start it and pull it into the shop and it wont start. Just cranks. Pushed it inside. Found out the smoke was steam from a split in the upper radiator hose. And then checked spark and only half the coil was firing. Coincidently I just got in the mail new MSD Coil, Wires, and Iridium plugs. So I tossed them all in and the car is still not starting. Checked for spark again and its wierd because at first you get a few good strong sparks but then it dies out and sometimes there will be no spark or it is a weak spark.
Any ideas? And once again its a 2003 PT GT 5spd.
EDIT: Also wanted to mention that the speedometer has not worked since I got the car. VSS Perf Error. Changed it and no difference. Got into it with a computer and it says that the computer is for an automatic transmission.
Jason
2003 PT Cruiser GT
1991 Mustang LX 5.0 Convt
1991 Dodge Spirit R/T
Old 05 Mar 2013, 08:50 am
Default Re: 03 PT GT 5spd: Wont Start
I'd stick with the spark issue.
What does a Camshaft/Crankshaft Position Sensor do?
The Camshaft sensor determines which cylinder is firing to establish injector synchronization and coil firing sequence in DIS systems. Crankshaft sensors set ignition timing, supply the RPM signal, and determine engine speed.
First, try a jump start, even though it's cranking, might not be enough to get things going.
Second, the Camshaft sensor (I know, no code) but it's the piece that makes the coil fire.
Also might want to hook it up to a scanner to get a better reading of what's going on.
Old 05 Mar 2013, 09:04 am
Agree (as usual) with Crewzin - just want to add that you shoudl get a Mopar sensor - many people have reported buying an aftermarket sensor is a bad choice - doesn't work or doesn't last as long as a genuine part.
Old 05 Mar 2013, 11:34 pm
Yeah I dont know why but my scanner doesnt really want to hook up with the car. It was a bitch just to get it to read out the codes. Its one of them Autosnap models which is not cheap and works great on my Mercedes at work.
For some reason it wont give me the real time data so I could look and see what signals are being read.
I will charge the battery though as that is a good point. It does look kind of old and small for the car.
Jason
2003 PT Cruiser GT
Old 08 Mar 2013, 11:12 pm
So I charged the battery, put in the correct ecm for a manual transmission, and put in a new cam sensor - car still wont start - ARGHHHH!!!
Im going to check compression tomorrow even though I know the belt isnt broken but maybe it jumped time and that is messing with the spark??
I know I dont want to replace the crank sensor unless im damn sure since that is $105!
Or maybe im just so unlucky that my stock coil went bad and the new MSD coil is bad too??? Any way to test that?
Jason
2003 PT Cruiser GT
Old 14 Oct 2014, 08:32 pm
I'm have the same problem, it started yesterday. Please tell me what you did??
Old 14 Oct 2014, 08:39 pm
Check for spark...
Old 15 Oct 2014, 08:10 am
I would suggest checking for a short at the Crank Sensor Connector. Check your wires at the plug connector to the crank sensor, they are to close to the exhaust the heat cracks the insulation off and create a short and no spark gets distributed if it happens.
02 wont start Sfos Tech & Performance Forum 15 10 Jan 2014 05:46 pm
I NEED HELP! CAR WONT START! AshHow Tech & Performance Forum 6 17 Dec 2012 01:22 pm
Car Wont start!! txgalant8 Tech & Performance Forum 6 06 Nov 2012 07:45 am
02 wont start anthonye559 Tech & Performance Forum 5 20 Sep 2011 11:44 pm
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
