New afterMarket radio cuts off randomly
Old 11 Mar 2013, 01:25 pm
Exclamation New afterMarket radio cuts off randomly
Just installed new aftermarket radio and for some crazy reason the sound cuts off randomly while driving but when I'm either at a stop light or in park the radio plays perfectly without cut offs I took it on a very bumpy road to see if maybe a wire is loose or something but music was playing fine still with cut offs during the bumps then it would play fine with bumps so I don't think wires are loose just the sound cuts off the radio and subwoofer keep going without any trouble what could this be 2006 touring
Old 11 Mar 2013, 01:53 pm
Default Re: New afterMarket radio cuts off randomly
i would check the ground and power wires. stereos are known to do that when they are starving for juice. the amp has it's own power and the pre-out doesnt send much power back to the amp, which would explain why it only affects the other speakers.
i ALWAYS solder and heat shrink EVERYTHING. you might even add an additional ground wire, since these cars seem to have problems with them.
you can pick up a cheap soldering iron kit with solder for $9-12 at radio shack.
Old 11 Mar 2013, 02:04 pm
Because of the random events of shutting off I would not altogether rule out simply a bad headunit?
Old 11 Mar 2013, 02:28 pm
Ray_Dockrey's Avatar
Where did you pull your power from?
radio/cd player cuts out gonzomania Sound and Security Forum 35 29 Aug 2013 11:42 pm
Aftermarket radio install superjew78 Sound and Security Forum 7 02 Aug 2012 09:17 pm
Aftermarket Radio Installation bjagd02 Sound and Security Forum 3 01 May 2011 01:56 pm
aftermarket radio install berk3066 Sound and Security Forum 5 28 Dec 2010 05:07 pm
Aftermarket radio help gmariconda Sound and Security Forum 1 05 Jan 2010 04:01 pm
